Thread: Help needed with AutoCAD R14
05-03-2016 #14
The trouble with AutoCAD comes when you create a mesh. At point of creation you have to define how many facets the mesh will have and you cannot go back and edit. You have to redraw if you want to change it. Each ENTITY can have completely different facet settings and they do not SCALE well. If you can stick to lines, arcs and circles then everything is fine and dandy. You can project lines and arcs into 2.5D by changing their THICKNESS but for real 3D work you need Solid Works or the clone thereof. That will allow you to adjust the facet angle and size parameters on the fly when you export the finished shape. CorelDraw is not an engineering product and should not be treated as such, it is for making pretties. You should only use it when pretties and engineering collide, usually realising graphic art and making signage.
I do like a good rant on Saturday morning, sets me up for the weekend. I shall go and blast 50 clays out of the sky with an antique muzzle loader tomorrow morning, bliss.Last edited by Robin Hewitt; 05-03-2016 at 10:41 AM.
a little more help needed
By terry1956 in forum Motor Drivers & ControllersReplies: 1Last Post: 29-02-2016, 05:52 PM -
3d AutoCad CNC machine parts.
By jcb121 in forum Open Source Designs & PlansReplies: 1Last Post: 09-10-2014, 10:18 PM -
Major issue with snapping to circles -Autocad 2013
By craigrobbo in forum AutoCADReplies: 8Last Post: 01-02-2014, 09:33 AM -
Concentric reducer in autocad
By Web Goblin in forum Computer SoftwareReplies: 1Last Post: 24-09-2012, 03:58 PM -
AutoCad 2007
By D-man in forum CAD & CAM SoftwareReplies: 15Last Post: 05-08-2012, 05:51 PM
