  1. #33
    Quote Originally Posted by Scott Damman View Post
    I took a little break from the machine and came back to it. Ended up being a debounce issue, it looks like my cable grounding wasnt as good as I thought. I doubled the debounce to 8ms and the MDI and Gcode both ran....
    Pretty darn cool to see it run on its own, I am so close to cutting...
    Here is a pic of the CSMIO-IPA Config window for setting debounce for anyone in a similar situation.
    Not good idea to use de-bounce because it affects all the inputs and slows down re-action time. Find the problem and fix asap, esp if using servos because want any inputs to re-act fast.
    Edit: Actually I see you only have set to 2 which isn't so bad thought you'd set it to 8 which would have been 32ms.
  1. BUILD LOG: First time build - Steel Frame CNC Router
    By examorph in forum DIY Router Build Logs
    Last Post: 19-10-2023, 06:25 PM
  2. BUILD LOG: New Build, Aluminium Frame Router/Mill
    By Davek0974 in forum DIY Router Build Logs
    Last Post: 31-08-2016, 05:28 PM
  3. BUILD LOG: Steel frame cnc router design/build
  4. BUILD LOG: First steel diy CNC router build
  5. BUILD LOG: 7' X 4' Steel frame build
