    Ger21's Avatar
    Lives in Detroit, United States. Last Activity: 3 Weeks Ago Has been a member for 9-10 years. Has a total post count of 651. Received thanks 90 times, giving thanks to others 0 times. Referred 1 members to the community.
    Most industrial servo driven routers use 25-32mm pitch screws, which virtually eliminates whipping. With steppers, you don't want to go that high because you lose resolution, but with 10,000 steps/rev with servos, resolution isn't an issue.
    Imo, on a machine that large, you want at least 1000ipm, preferable closer to 1500ipm. With a 10HP spindle, you should have no trouble cutting sheet goods at 1000ipm if you want.
    Gerry
    UCCNC 2022 Screenset
    Mach3 2010 Screenset
  2. The Following User Says Thank You to Ger21 For This Useful Post:
  1. BUILD LOG: First time build - Steel Frame CNC Router
    By examorph in forum DIY Router Build Logs
    Last Post: 19-10-2023, 06:25 PM
  2. BUILD LOG: New Build, Aluminium Frame Router/Mill
    By Davek0974 in forum DIY Router Build Logs
    Last Post: 31-08-2016, 05:28 PM
  3. BUILD LOG: Steel frame cnc router design/build
  4. BUILD LOG: First steel diy CNC router build
  5. BUILD LOG: 7' X 4' Steel frame build
