10-03-2016 #11
Sometimes I forget about the speed of the screw also being an important factor. I put together a little table for resolution based on ballscrew, based on my calculations I need to go with a higher pitch or up the gear ratio to keep the speed ~80% max. Upping the ratio of course hurts resolution so Im looking for a 20 pitch screw. Higher pitch also helps keep the ballscrew speed down, but of course hurts resolution per mm.
Thoughts on this?
BUILD LOG: New Build, Aluminium Frame Router/Mill
By Davek0974 in forum DIY Router Build LogsReplies: 101Last Post: 31-08-2016, 05:28 PM -
By Ricardoco in forum DIY Router Build LogsReplies: 6Last Post: 28-10-2012, 06:02 PM
