07-03-2016 #11
Our friend Fred from BST Automation has 1kw servo motor + drive for 332euro +shipping which will cost you in total~400$ for the combo when you buy 4.
I am not sure you need exactly 1kw if you go with rotating ball nut. But as prices are similar. I think you will need 0.75kw geared like mine 20t:30t and that will give you speed of 20000mm/min on the long axis/ball screw with rotating nut/.
BUILD LOG: New Build, Aluminium Frame Router/Mill
By Davek0974 in forum DIY Router Build LogsReplies: 101Last Post: 31-08-2016, 05:28 PM -
By Ricardoco in forum DIY Router Build LogsReplies: 6Last Post: 28-10-2012, 06:02 PM
