    Quote Originally Posted by Scott Damman View Post
    From my table above I am looking at a 2525 screw for the long axis. If I do a 2:3 ratio I get 37.5 mm travel per one motor revolution. 37.5/10,000 pulses = 0.00375 mm per pulse. This would be the best resolution. Or 0.0001476 inch resolution. This seems plenty good to me but thought I would ask
    This reduces the speed of the screw considerably to reach the same machine speed and actually gives me some headroom on the motor max speed as well.
    At the moment I am planning on rotating the screw and putting in multiple ballscrew supports. Something like...
    If I choose to do rotating ballnut I will need to recalculate the inertia and just make sure everything still matches up. I am leaning the other way as my parts are coming back around $300 usd per side....
    Does this sound like a reasonable solution?
    Got my gear ratio backward. I need to redo my calculations...
    Alright new table now that I got the gearing correct the ballscrew and motor speeds were correct but I took the ballnut travel per motor rev the wrong way.
Name:	Ballscrew precision.JPG
    So based on these numbers still looking at 25mm lead screw. With a ratio of 2:3
    Ballnut travel per motor rev 25*0.66 = 16.5mm
    Precision mm = 16.5/10,000 = 0.00165 (is this real? i.e. with a quadrature resolver will I truly get 10,000 counts per motor rev?)
    1600 rpm ballscrew speed to get to 40,000mm/min (~1500ipm)
    Motor speed of 2424rpm (67% of max motor speed)
    So am I looking good here? The precision seems great and the speeds would be very acceptable with some headroom on the motor speed.
  1. BUILD LOG: First time build - Steel Frame CNC Router
    By examorph in forum DIY Router Build Logs
    Last Post: 19-10-2023, 06:25 PM
  2. BUILD LOG: New Build, Aluminium Frame Router/Mill
    By Davek0974 in forum DIY Router Build Logs
    Last Post: 31-08-2016, 05:28 PM
  3. BUILD LOG: Steel frame cnc router design/build
  4. BUILD LOG: First steel diy CNC router build
  5. BUILD LOG: 7' X 4' Steel frame build
