    * A QUOTE FOR THIS HAS NOW BEEN ACCEPTED *
    RFQ: Aluminium plate, basic dimensions 150mm x 140mm x 12mm
    16 holes machined to accomodate M5 cap bolts - not threaded, with cap sunk under surface of material.
    19 additional holes drilled/machined and tapped to take a M6 bolt
    You to supply material, machine, and deliver to Lancashire, UK.
    (Background, this is a first attempt to mount a replacement spindle onto the Z-column on a StarMill machine... I would attempt this, except the size is rather too large to work on the StarMill as a single operation)
    Mike
    Attached Files Attached Files
  1. where to get aluminium plates cut and drilled
    By reefy86 in forum Gantry/Router Machines & Building
    Last Post: 30-08-2015, 12:28 PM
  2. RFQ: RFQ: Gantry in Aluminium plate
    By IanS1 in forum Projects, Jobs & Requests
    Last Post: 03-10-2014, 03:51 PM
  3. WANTED: 100mmx100mm 6mm aluminium plate/sheet.
    By Isaac in forum Items Wanted
    Last Post: 06-02-2014, 12:11 AM
  4. RFQ: Rounded slot milled through 15mm Aluminium plate
    By TonyD in forum Projects, Jobs & Requests
    Last Post: 15-02-2013, 11:20 AM
  5. what is aluminium plate
    By martin54 in forum General Discussion
    Last Post: 11-10-2012, 01:44 AM
