I could but won't get into slanging match with someone so narrow minded. I'm also not saying I would have used 0.75mm2 because I wouldn't have. However only because I have 1.0mm2 & 1.5mm2 which use all the time. If I'd only had 0.75mm would have used it.
The point of my first post was more to re-assure the OP "Bee" that his choice, which he'd already purchased before you posted would be fine. This by now he surely knows because some Muppet started up the thread again 3 mth's after he posted.!!
27-05-2016 #2
OK, so you would not use 0.75mm2, just want to comfort someone who bought the cable... well, the reason for the Muppet to start up the thread LESS than 2 mnts after Bees last post was to try to open the minds of those who are not sure, so they just follow the stream and go after the majority on these forums. I think that can hardly be called narrow minded, more like an effort to help. Considering the costs of the cable, and compared to the price of the CNC the "use what I have available" principle is really very narrow minded and wrong. Apparently you are more keen on name calling than admitting that I was right, there are ONLY advantages of a stronger, better cable, no disadvantages. You don't answer my question because there is just one answer. Anyway, at least in this post, you made it clear that the 0.75mm2 would have not been your choice, so basically, we actually agree.
...and in all honesty, if you really know what I think you know, then I don't think you would have used 0.75mm2 cable if that was all you had at home. I think you would have done the same I would have done, ordered 1.5mm2 and possibly used the thinner one until the better one arrives...
Like I said, what works and what is right are not necessarily the same.
27-05-2016 #3
I wasn't name calling more stating the obvious. IMO it's muppet with over active Ego that posts reply to question which had been answered already and acted upon by the OP months ago.!
I don't doubt your knowledge of electricker and in principle Yes your correct so if your Ego needs a massage I'll glady ablige and say I agree that 0.75mm shouldn't be first choice.
However the fact still remains 0.75mm2 would and will work perfectly fine. All your arguments regards Cable strength, ridgidty etc are mute because it's stupid thing to rely on cable for strength when it should be supported with bracket. The Only thing that matters is if cable can handle the load of the device it's powering while in prolonged use and clearly it can.
Why would you presume to predict what I would do.? . . . I don't know me so you or anyone else stands NO chance predicting my actions.!!
If I'd took the time effort to fit it then I'd consider it safe and it would stay on. The ONLY time I might do this is in emergency situation to get machine up and running.
This is contradiction.!! . . . . . If it's working Correctly then it's Right.!!
27-05-2016 #4
27-05-2016 #5
27-05-2016 #6
27-05-2016 #7
27-05-2016 #8
27-05-2016 #9
27-05-2016 #10
You do not say that you prefer or recommend using thicker cables to be on the safe side or you normally have them at hand or you don't mind wasting a valuable metal with finite resource here on earth. But you say that a 1.5KW spindle cable should be 1.5mm2 and the control cables 0.75mm2 (when most control cables are 0.25mm2). This approach is all wrong!
1.5 kw Chinese spindle cable
By 142victoria in forum Generic Chinese SpindlesReplies: 4Last Post: 02-11-2015, 09:53 AM -
motor and spindle cable size?
By paulus.v in forum General ElectronicsReplies: 4Last Post: 04-02-2014, 10:18 PM -
Ballscrew Thickness!
By AdCNC in forum Lead Screws, Nuts & SupportsReplies: 51Last Post: 03-02-2014, 06:01 AM -
Adding earth cable to 2.2Kw Chinese Spindle
By Dwayne Dibbley in forum Generic Chinese SpindlesReplies: 4Last Post: 13-03-2013, 04:04 PM -
VFD Cable and 2.2kw spindle wiring
By Flamered in forum Spindles & Drive MotorsReplies: 7Last Post: 24-08-2012, 07:29 PM
