    Not replying to any single post here:
    Considering only resistance (okay, a motor is largely inductive - it makes the maths slightly trickier, but there is a significant resistive element to the motor and the basic premise remains)
    Simply, given the same conductor type, 0.75mm2 cable has a higher resistance per unit length than 1.5mm2. Similarly, 1.5mm2 has a higher resistance per unit length than 2.5mm2. That fact is irrefutable.
    The power dissipated in the cable run is proportional to the resistance.
    Also, the voltage drop across a cable run is proportional to the resistance. The higher the resistance, the greater the voltage drop across the cable run.
    The voltage drop across the cable run is proportional to the square of the current drawn. So, under load, with greater current draw, the voltage drop across the cable run increases at the square-law of the current, and implicitly, the load.
    The voltage at the spindle is the terminal voltage of the VFD, minus the voltage drop across the cable run.
    The mechanical power provided by the spindle is proportional to the terminal voltage of the VFD.
    So, the lower the CSA of the cable run, the lower the voltage at the spindle. This drop increases as the load increases. This impacts directly the available power of the spindle. Cable CSA is related to performance.
    Of course, the standard cable ratings easily found on the interweb don't consider the performance of the spindle, only the safe operating mode of the cable under domestic and industrial applications - given the heating effect of the dissipated energy on the cable, and - importantly - the longevity and integrity of the insulation. You might find that a particular cable works, but that the insulation fails after prolonged use.
    The spindle manufacturer will provide a design specification for the spindle. This /should/ (I have to provide that caveat for our illustrious Chinese manufacturers who are not unknown to put anything that sounds good in the manual without reference to reality) allow the spindle to operate as designed. It is not unreasonable to expect then, that if you compromise that design, you'll compromise the performance of the spindle.
    Finally (I need to get back to the bottle of wine), don't design a system assuming any strands on a multistranded cable will fracture - at that point the mechanical design of the system has already failed and catastrophic failure of the cable will occur in short time.
    An analogy. If an architect specified a 152x89 RSJ. Would you chose to replace this with a 127x76 RSJ that you had lying around? It might well work, the building would probably stay upright after you've finished it. Hey!, the architect is clearly a fool.
  2. The Following User Says Thank You to Doddy For This Useful Post:
  3. #2
    I might be a bit fick but did you just say "Fatter cable will make spindle go faster"?
    Quote Originally Posted by lucan07 View Post
    Not on a VFD driven spindle - it'll give more torque. Thinking about my old DC spindle (not really the case discussed here) - in that case yeah more spins.
    Groan: That was bad wine last night.
  5. #4
    bee's Avatar
    Lives in Rochester, United Kingdom. Last Activity: 29-05-2016 Has been a member for 9-10 years. Has a total post count of 6. Received thanks 1 times, giving thanks to others 2 times.
    Right. Well... this has all taken quite a turn. Who'd have thought all hell would break loose several months later. I'm the OP and just to justify my choice of cable, I must admit I had no idea what these cables looked like in real life, so getting the lightest possible seemed like the right thing to do. It's working very well, and since there still are forum voices that say it's okay, I'll stick with it. I do understand that more is better in these things, but it's all installed and, I'd like to think, behind me.
    It's been interesting, though, and thanks to all. This is a great and helpful forum!
    Bernard
  6. The Following User Says Thank You to bee For This Useful Post:
  7. #5
    Hell?, that wasn't hell!, try posting something in the RFQ section!
    Glad it's all worked out for you :)
  8. Quote Originally Posted by Doddy View Post
    Not wishing to fuel the fire, but what cross section cy are people generally using between driver and stepper?! (genuine question!)
    Signed foolish architect
    ps. This video is quite useful for those with less experience when it comes to connecting steppers to the cable itself, I would be interested to hear comments on his methodology from those who have done this many times before... - https://www.youtube.com/watch?v=Xbiipb6nnZg
  9. #7
    Lives in Marple Stockport, United Kingdom. Last Activity: 11 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,346. Received thanks 618 times, giving thanks to others 87 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Joe I generally use 4 core 1mm CY cable and earth the screen to a star point in the control box and I don't see the point of stripping such a lot of cable back 6" is more than enough. But I make these for the back of the motorClick image for larger version.
  10. Quote Originally Posted by Clive S View Post
    Thanks Clive, I thought he stripped a lot off! Do you 3D print those yourself?
  11. #9
    Quote Originally Posted by JoeHarris View Post
    The white one I printed, the black one was milled from one of those fencing posts made out of car tyres. They are 100x100 square so I band-sawed it down the centre then it was possible to get one out of each half. The trouble with it is that the stuff if full of bubbles in the centre but they were fine. I have also made them from various plastics which are very nice.
    They are available like http://www.soigeneris.com/nema_23_st...r-details.aspx But I have seen them for about 13 euro from Europe somewhere.
  1. 1.5 kw Chinese spindle cable
    By 142victoria in forum Generic Chinese Spindles
    Last Post: 02-11-2015, 09:53 AM
  2. motor and spindle cable size?
    By paulus.v in forum General Electronics
    Last Post: 04-02-2014, 10:18 PM
  3. Ballscrew Thickness!
    By AdCNC in forum Lead Screws, Nuts & Supports
    Last Post: 03-02-2014, 06:01 AM
  4. Adding earth cable to 2.2Kw Chinese Spindle
    By Dwayne Dibbley in forum Generic Chinese Spindles
    Last Post: 13-03-2013, 04:04 PM
  5. VFD Cable and 2.2kw spindle wiring
    By Flamered in forum Spindles & Drive Motors
    Last Post: 24-08-2012, 07:29 PM
