    Post the G-code file and lets see the code.
    N0010 (Filename: Big A3.tap)
    N0020 (Post processor: Mach3 plasma THC with scriber and backlash compensation.scpost)
    N0030 (Date: 05/03/2016)
    N0040 G21 (Units: Metric)
    N0050 F1
    N0060 G53 G90 G40
    N0070 (Part: Big A3)
    N0080 (Operation: Outside Offset, LAYER_1, T3: Plasma 3mm-30A-850mm-1.58mm cut height)
    N0090 G00 X15.6144 Y12.5939
    N0100 G28.1 Z20.00 F500.0
    N0110 G92 Z0.0
    N0120 G00 Z1.5000
    N0130 G92 Z0.0
    N0140 G00 Z4.0000
    N0150 M03
    N0160 G04 P0.6
    N0170 G01 Z2.8000 F150.0
    N0180 X16.6791 Y10.0961 F850.0
    N0190 X19.8560 Y9.0754
    N0200 X22.8081 Y8.5534 F510.0
    N0210 X23.2751 Y8.0316
    N0220 Y5.0316
    N0230 Y3.0000 F850.0
    N0240 X23.2752 Y0.0000 F510.0
    N0250 X23.1118 Y-0.3806
    N0260 X22.7234 Y-0.5243
    N0270 X19.7256 Y-0.4140
    N0280 X19.5250 Y-0.4096 F850.0
    N0290 X16.2684 Y-0.1946
    N0300 X12.9140 Y0.4530
    N0310 X9.7047 Y1.6244
    N0320 X6.9448 Y3.1894
    N0330 X4.4943 Y5.2049
    N0340 X1.9916 Y8.3236
    N0350 X0.3023 Y11.9481
    N0360 X-0.4768 Y15.8702
    N0370 X-0.3009 Y19.8651
    N0380 X0.8199 Y23.7036
    N0390 X2.7076 Y27.1242
    N0400 X5.2379 Y30.1008
    N0410 X8.3099 Y32.5146
    N0420 X11.8006 Y34.2690
    N0430 X17.0636 Y35.9060
    N0440 X22.4926 Y36.8574
    N0450 X41.8802 Y40.3266
    N0460 X41.7476 Y44.9323
    N0470 X41.5397 Y46.6742
    N0480 X39.3169 Y50.6968
    N0490 X33.8596 Y53.7325
    N0500 X26.2101 Y54.6128
    N0510 X19.4976 Y53.1823
    N0520 X15.4249 Y49.6995
    N0530 X13.5327 Y46.0347
    N0540 X12.4418 Y43.2411 F510.0
    N0550 X11.8739 Y42.8903
    N0560 X8.9014 Y43.2956
    N0570 X4.7687 Y43.8592 F850.0
    N0580 X1.7962 Y44.2645 F510.0
    N0590 X1.4233 Y44.5043
    N0600 X1.3669 Y44.9440
    N0610 X2.2191 Y47.8202
    N0620 X2.2266 Y47.8476 F850.0
    N0630 X3.2325 Y50.7950
    N0640 X5.2232 Y54.4048
    N0650 X7.9755 Y57.4738
    N0660 X11.6546 Y60.1211
    N0670 X15.7954 Y61.9647
    N0680 X21.6148 Y63.4567
    N0690 X27.5792 Y64.1762
    N0700 X33.5864 Y64.1110
    N0710 X39.1003 Y63.1710
    N0720 X44.3471 Y61.2326
    N0730 X46.9075 Y59.6615
    N0740 X49.0885 Y57.5957
    N0750 X50.7961 Y55.1243
    N0760 X51.9568 Y52.3536
    N0770 X52.8822 Y48.3915
    N0780 X53.2996 Y44.3442
    N0790 X53.3356 Y22.7635
    N0800 X53.7209 Y11.2433
    N0810 X54.3125 Y8.2339
    N0820 X55.5566 Y4.3315
    N0830 X56.5823 Y1.5125 F510.0
    N0840 X56.5247 Y1.0271
    N0850 X56.0921 Y0.7996
    N0860 X53.0921
    N0870 X48.3272 F850.0
    N0880 X45.3272 F510.0
    N0890 X44.8286 Y1.1602
    N0900 X43.9445 Y4.0268
    N0910 X43.6966 Y4.9088 F850.0
    N0920 X42.9361 Y7.9071
    N0930 X41.6861 Y6.9167
    N0940 X39.7115 Y5.4403
    N0950 X35.0065 Y2.8267
    N0960 X29.9713 Y0.8867
    N0970 X27.1101 Y-0.0142 F510.0
    N0980 X26.6484 Y0.0702
    N0990 X26.4386 Y0.4900
    N1000 Y3.4900
    N1010 Y5.2831 F850.0
    N1020 X26.4385 Y8.2831 F510.0
    N1030 X26.8227 Y8.7889
    N1040 X29.6832 Y9.6912
    N1050 X33.2111 Y11.1111 F850.0
    N1060 X36.5363 Y13.1807
    N1070 X39.7573 Y17.0997
    N1080 X41.2449 Y21.9495
    N1090 X41.8613 Y31.1315
    N1100 X39.1532 Y30.2866
    N1110 X35.6880 Y29.2892
    N1120 X28.6139 Y27.9105
    N1130 X21.5887 Y26.7631
    N1140 X15.3494 Y24.4012
    N1150 X13.0505 Y22.3261
    N1160 X11.7379 Y19.5211
    N1170 X11.6177 Y16.4265
    N1180 X13.3167 Y12.5964
    N1190 X16.6791 Y10.0961
    N1200 X18.3443 Y10.8059
    N1210 M05
    N1220 G00 Z20.0000
    N1230 X0.0000 Y0.0000
    N1240 M05 M30
    Letter a test.dxf
    This isn't perfect but give it a try to see if its any better.
  4. The Following User Says Thank You to Web Goblin For This Useful Post:
  5. #4
    I've posted the gcode below, thanks
  6. #5
    I loaded that into Mach3 and zooming in (not too far either) in the toolpath window on the toolpath tab it looked more like a series of straight lines than curves
    - Nick
  7. The Following User Says Thank You to magicniner For This Useful Post:
  8. #6
    Wow, your right! I rarely open the Mach3 toolpath window and its most definitely reading it as a series of straight lines. The question is why?
  9. #7
    I'm guessing that your Post Processor isn't outputting code that's compatible with your Mach3 configuration.
    Sadly my expertise on these is limited to my own system but I'm sure someone with greater wisdom will enlighten us ;-)
    Regards,
    Nick
  10. #8
    I just imported the dxf kindly uploaded by Web Goblin directly into Mach3, getting mach3 to generate the code. No segments, nice and smooth?
    Indeed Hopfully someone with greater wisdom will enlighten us ;-)
    A quick look at the gcode immediately shows that it's a series of line segments - there's a G1 near the beginning, then just a series of coordinates thereafter which will also use the implied G1. Not a G2/G3 in sight.
    My guess is that the DXF you are exporting, for some reason, is using straight line approximations and not curves or arcs. I've had that problem exporting from Adobe Illustrator and it turned out to be that I was not using the latest available DXF format. Can you explore that?
  12. #10
    Quote Originally Posted by marbles View Post
    That points the finger firmly at the software you're using to generate your dxf files, stop using it and use something people who don't have the issue use.
  13. The Following User Says Thank You to magicniner For This Useful Post:
  1. My plasma build 8 x 4
    By drumsticksplinter in forum DIY Plasma Build Logs
    Last Post: 01-02-2014, 10:39 PM
  2. RFQ: Plasma job...
    By Boscoe in forum Projects, Jobs & Requests
    Last Post: 17-09-2013, 08:43 PM
  3. My first CNC plasma
    By Walterronny in forum DIY Plasma Build Logs
    Last Post: 20-02-2013, 02:13 AM
  4. Which Plasma Cutter to buy?
    By AndyG in forum General Discussion
    Last Post: 02-12-2011, 09:34 AM
  5. plasma cad
    By jamied in forum Computer Software
    Last Post: 20-08-2010, 03:33 PM
