Thread: VFD interference problem
06-03-2016 #2
06-03-2016 #3
Yes but if I order the PMDX 126, 160 Euros + tax when it gets here, you're looking at the same price than the 230 Euro 4 axis motion controller they've got at CSLabs. Plus, really, I think I can re-use it in the future for another build.
Are there any choices other than CSLab, for a decent controller ?Last edited by eurikain; 06-03-2016 at 09:59 PM.
06-03-2016 #4
Yes there are but by time you have bought decent BOB to match they are not any cheaper than IP-M. While some like Ethernet Smooth stepper may beat IP-M on features(that you won't probably use) Nothing touches the IP-M on quality for same money.
Just be aware the IP-M isn't ideal if your using Slaved motors.
06-03-2016 #5
What if I buy an ethernet smooth stepper as you told me a few weeks back ? ESS smooth stepper ? That would prevent the ground loop going back to the PC since it's ethernet based.
07-03-2016 #6https://emvioeng.com
07-03-2016 #7
Nope, the BOB is powered only using a 5VDC external power supply. Weird that I'm the only person with this issue.. I've got the exact same board as the one you sell on your website. Typical cheap Chinese BOB. But it works for everyone else.. why not for me :'( ?
I have a PCI parallel port expansion board. It might be interesting to install it and test if it improves or fixes the ground loop. It might be the native parallel port of my PC that's not working properly. I'll give it a try on Thursday.Last edited by eurikain; 07-03-2016 at 12:59 PM.
07-03-2016 #8
It will with the ESS which think pulls Gnd from PC like the BOB but not with IP-M which is isolated from PC and pulls Gnd to Mains Earth. It also uses Differential signals with isolated Inputs which is why it's so very good at not being affected by noise.
That said you still need to be 100% sure it is the BOB and not some other cause.?
Noise, Interference, and unexplained electrical behaviour
By g4ghp in forum General ElectronicsReplies: 4Last Post: 24-04-2014, 11:39 AM -
Bearing interference fit / press fit
By Mad Professor in forum General DiscussionReplies: 5Last Post: 30-09-2012, 11:26 PM -
19inch Rack Enclosure - interference?
By Washout in forum General ElectronicsReplies: 12Last Post: 22-09-2012, 09:10 PM -
Problem with X
By gorbo in forum General DiscussionReplies: 17Last Post: 24-02-2011, 05:33 AM -
Z Problem
By airwolf in forum Machine DiscussionReplies: 2Last Post: 10-11-2009, 08:08 AM
