Thread: VFD interference problem
15-03-2016 #13
Rob is correct that you shoudln't be spending money without sorting the problem. While the Cslabs are good with noise this doesn't mean it will cure your problem. The noise could be being picked up in number of places, the signal cables to drives for instance which are between Cslabs and Drives.
You NEED to find and remove the noise at the SOURCE. Buy mains Filter for both the Control box and the VFD before buying anything else.
Noise, Interference, and unexplained electrical behaviour
By g4ghp in forum General ElectronicsReplies: 4Last Post: 24-04-2014, 11:39 AM -
Bearing interference fit / press fit
By Mad Professor in forum General DiscussionReplies: 5Last Post: 30-09-2012, 11:26 PM -
19inch Rack Enclosure - interference?
By Washout in forum General ElectronicsReplies: 12Last Post: 22-09-2012, 09:10 PM -
Problem with X
By gorbo in forum General DiscussionReplies: 17Last Post: 24-02-2011, 05:33 AM -
Z Problem
By airwolf in forum Machine DiscussionReplies: 2Last Post: 10-11-2009, 08:08 AM
