    hi folks just wondering if anyone has or had the same issue as myself with there machine.
    doing a circle test on it today as i have just got everything going and it sounds if its going to stall when trying to do a circle. on the other hand i can move it in both directions at once with the key board in jog.
    i have attached a link to a video
    https://youtu.be/z0OFB0u54cY
    Turn the feed rate up.
    Just sounds like very low feed rate and because your using R&P with possible Low resolution then your motors are hardly spinning. Where as at rapid they are spinning at higher rpm so sound better.
    Lives in Marple Stockport, United Kingdom. Last Activity: 19 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,346. Received thanks 618 times, giving thanks to others 87 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Quote Originally Posted by Davo242 View Post
    What drives and power supply voltage did you end up with?
    They are still the same ones running at 36v Clive only I made up a gear box at a 3:1 ratio running far smoother now. Il work with the drivers until they die and then upgrade to a better set lol
    Quote Originally Posted by Duffman View Post
    Well you could try measuring the voltage of the power supply when it is under load cutting the circle and see if it drops much
    edit Not sure who I have answered now Davo242 or Duffman !!
    Ok if it does Clive do u think il need to change my drivers because I cant give them much more juice ?? Funny tho it jogs in both directions at once
    Tried running it at a faster speed sounds a lot better now thanks for the help guys
  1. funny movement on solidcam turning
    By eamo1978 in forum Solidworks
    Last Post: 23-06-2014, 08:16 AM
  2. Dell monitor making a funny noise !
    By Lee Roberts in forum Monitors
    Last Post: 13-09-2013, 12:11 PM
  3. Funny machining pics
    By oscar in forum Workshop & Equipment
    Last Post: 30-05-2013, 03:55 PM
  4. something quite funny
    By johngoodrich in forum Machine Discussion
    Last Post: 12-09-2011, 10:48 PM
  5. Motor noise
    By M250cnc in forum General Electronics
    Last Post: 25-11-2010, 02:06 PM
