11-03-2016 #9
Only reason I got involved was because i hoped to offer you that i would build you what's in the pic, for material cost only.
However your 3 hours away so I think the logistics have killed it, I know a half pallet will be about £60...
3x2 will be fine it's the cross bracing that will count, mine has ply sides sides and triangles on the back top corners half the leg length in both directions, it's solid as a rock I can assure you...no need for a slege hammer to crack an egg.
Two years old, 12 months weathered (was an outside work horse while I built my workshop) and 24 months later is still as strong as the day I built it.
Are you sure you can't be tempted to built your own, if you get the wood yard to cut to size all you got a do is screw/bolt it together?
.MeLee
Help choosing a cnc lathe
By Hellfire in forum Marketplace DiscussionReplies: 11Last Post: 10-04-2016, 02:07 PM -
need help! choosing right kit
By msacnc in forum Gantry/Router Machines & BuildingReplies: 26Last Post: 17-09-2014, 09:41 AM -
choosing a spindle.
By charlieuk in forum Spindles & Drive MotorsReplies: 15Last Post: 16-01-2014, 08:18 AM -
Small workbench drum sanders ?
By Fivetide in forum Marketplace DiscussionReplies: 7Last Post: 26-11-2013, 12:53 PM -
Advice on some basic tools
By GTJim in forum General DiscussionReplies: 10Last Post: 22-09-2011, 12:16 PM
