Thread: Steps per unit daft question
12-03-2016 #14
No harder just decimal point is in different place.!!
Well your sort of correct but like most things in CNC it's not that simple.!!
Resonance is big factor in stepper performance and lower micro stepping often make the motors run in area that they get affected by resonance. This cripples the performance.
Jim mentioned it briefly but playing with micro stepping can drasticly increase performance. Every machine resonates different so there's no one setting that suits all machines. ~However rule of Thumb is that higher MS runs smoother but at the cost of stress on the pulse engine. Basicly many more pulses are needed. So if your using the Parallel port some times running high MS can tax the parallel port which struggle to cope with supplying consistant train of pulses. This degrades the quality and frequency and all sorts of strange things can happen. Things from missed steps to poor performance or stalling motors.
That's why External motion controllers are much prefered if running machines at higher feeds. like routers. Small machines like mills etc can get away with using PP and lower MS because they rarely run in Mid band or higher speeds which is where steppers/drives get affected most.
daft question on LED indicators and high VDC
By dsc in forum General ElectronicsReplies: 35Last Post: 15-10-2014, 09:29 PM -
RFQ: Daft Punk Build
By FIREWIRE in forum Projects, Jobs & RequestsReplies: 0Last Post: 19-04-2013, 02:34 AM -
I promise I will stop asking daft question soon. Ish.
By D.C. in forum Gantry/Router Machines & BuildingReplies: 27Last Post: 15-10-2012, 11:37 PM -
A daft question about vibration damping
By D.C. in forum Gantry/Router Machines & BuildingReplies: 11Last Post: 11-10-2012, 09:57 AM -
Unit Conversion Tool 5.1
By Lee Roberts in forum Machine DiscussionReplies: 0Last Post: 27-02-2008, 02:14 PM
