    Quote Originally Posted by hoezap View Post
    Koromatias may you please tell me the difference between composition of the material and grade of the material, i know the composition indicates all the percenteges of carbon, airon, and any other component, but what do you indicate with a grade?
    OK so composition just is the mix of materials as you already know. Once you mix them all you can then do lots of different processes to achieve the "Grade". Grade is a very broad term actually. It can encompass many meanings. Post metal processes, material properties, quality, inspection requirements, etc etc.
    For example you can heat treat certain metals,(quench, temper) to make them harder. You can cold forge some to to make them stronger.
    Quality wise. For example for the same material and heat treat you can accept differing percentage of defects or flaws. There's are usually set out in standards like ISO/Aisi etc. Of course a customer can also set out specifications and requirements and make their own grading system. The supplier would then need to cherry pick the raw material.
    So when sellers of various trinkets say aerospace grade titanium it could mean anything. To me it just shows the seller is clueless and probably used the most common grade or whatever was handy. Surgical grade stainless is another one that makes me laugh.
    My advice to you if you want to know more about the materials you are working with is to find the suppliers or mills documentation. The datasheets will explain many aspects of the material and grading. If the material is generic and not proprietary you can even look up the corresponding iso or national standard
    https://emvioeng.com
    It's iron man isn't it? You are planning to build a suit.
    The tricky bit is the power source
    There's no trick to it Robin.? . . . . You can go around any city about 2am and see the Power source of Iron Man.!! . . Beer and kabab..
    Thank you very much for your teaching komatias
    how can you measure the grade of the material and what sort of information can you achieve from it in terms of machining
    Thank you very much indeed again for your time
    Nothing is secret:
    So who Killed Kennedy and where is Shergar What happened to Lord Lucan.? Whats the composition of Chobham Armour.?
    Keep it down I am trying to remain anonomous.
  8. The Following User Says Thank You to lucan07 For This Useful Post:
  9. #8
    Thank you very much for the links Boyan Silyavski, however i can see both of your links talk about USA and not UK so may be in UK there are different roles... Thank you very much indeed again for your support
  10. #9
    http://www.masteel.co.uk/armour-steel.htm
    steel composition
    https://www.gov.uk/government/news/n...wcased-at-dsei
    look at google for bainite sword, so you will see how its done
    most of the steels for one or another reason have been used in knife making/ a broad term which includes swordmaking too/ , so here is a very full interactive table of steels with their chemical properties for reference:
    http://zknives.com/knives/steels/steelchart.php
    In this world they love to use "super" names but at the end of the day all will be some typical tool steel with sth little changed for added benefit. I looked at the american steel data and more or less it seems typical high carbon steel
    So to answer the question on what numbers to look for when thinking about machining steels:
    The yield strength, the elongation and the ultimate tensile strength and the hardness. The higher these numbers the more of a bugger a material is to machine.
    What you need to know is the surface speed that works best for a given material, luckily the suppliers will have a good idea what this is so you can find it in their datasheets.
    From the surface speeds you can calculate the various other numbers you need.
    Plenty of literature on the web and of course cart loads of reference books with the theory of chipping and all the other stuff. I will send you the title of my reference when I get home.
  1. DIY CNC machine for steel?
    By lukeleb2010 in forum Milling Machines, Builds & Conversions
    Last Post: 21-08-2021, 09:04 PM
  2. Replies: 41
    Last Post: 08-02-2014, 11:37 PM
  3. RFQ: Steel rolling
    By D-man in forum Projects, Jobs & Requests
    Last Post: 30-09-2013, 01:12 PM
  4. What is Steel 25BG?
    By Tenson in forum Metalwork Discussion
    Last Post: 03-08-2013, 11:08 AM
  5. WANTED: Steel Off-cut!
    By Tenson in forum Items Wanted
    Last Post: 27-04-2012, 05:59 PM
