16-03-2016 #19
I'm glad i titled this part as fairly advanced ;)
Sheet cam can't isolate parts of paths, only complete entities.
I have taken all the 3mm holes off the job now and will use a steel drilling jig to drill them as a second op, five of them must match up with another part that is drilled and tapped edge-on a strip of 5mm alu so this part must be jig-drilled and to make sure holes match both parts get jig drilled.
That also speeds up the time on the mill.
It seems i have 3 options now,
1 - remove the loops at the ends of the slots and jig-drill after, cutting just a straight slot
2 - as suggested, create a duplicate part of just that area and cut between roughing and finish passes.
3 - Create a new layer and put three straight slots and smaller loops on the ends on it and cut that between rough and finish passes, allowing the finish pass to take the loops to final size.
I think I would try opt 3 as a first go, seems to make most sense to me - 3 short slots opposed to a larger path.
Beginner Moving Gantry Build? Read This!
By Tenson in forum Gantry/Router Machines & BuildingReplies: 3Last Post: 23-05-2018, 05:30 PM -
Garage CNC - A gantry style machine design
By fandango in forum Gantry/Router Machines & BuildingReplies: 14Last Post: 21-03-2014, 01:38 AM -
Truss style Gantry
By D.C. in forum Gantry/Router Machines & BuildingReplies: 28Last Post: 15-12-2012, 07:23 PM -
A few questions to start a DIY mini CNC
By purple_rob in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 03-08-2009, 11:08 PM -
Vertical moving gantry????
By Ross77 in forum Gantry/Router Machines & BuildingReplies: 9Last Post: 03-06-2009, 08:34 PM
