    Yep, already on that ;)
    I just revisited the original plans for the part with the notch in it and it appears it's non-critical so I have altered it from 4mm wide and square to 5.1mm wide and half-round so the roughing tool will rip out most of it and I can try the 2.5mm DOC on the finish pass again - the 0.6mm cuts were where most of the time was eaten.
    While it was running today I was also making other stuff so the time taken is not critical to a tight degree, once I get going I can finish one set of parts while the next is running - there are holes to drill and tap etc. Demand is not massive for these but crucially it means I don't have to send them out for laser cutting anymore.
    I can also move another part I make from the plasma cutter to the mill as the quality is higher and finishing/clean-up time would be far less as plasma leaves a very rough edge on aluminium.
    Just need to sort out a better bucket for the cooling water, possibly some sort chip management, and some better cutting fluid.
    I might also try some low-speed tests just to see how low she can go.
  1. Beginner Moving Gantry Build? Read This!
    By Tenson in forum Gantry/Router Machines & Building
    Last Post: 23-05-2018, 05:30 PM
  2. Garage CNC - A gantry style machine design
    By fandango in forum Gantry/Router Machines & Building
    Last Post: 21-03-2014, 01:38 AM
  3. Truss style Gantry
    Last Post: 15-12-2012, 07:23 PM
  4. A few questions to start a DIY mini CNC
    By purple_rob in forum Gantry/Router Machines & Building
    Last Post: 03-08-2009, 11:08 PM
  5. Vertical moving gantry????
    By Ross77 in forum Gantry/Router Machines & Building
    Last Post: 03-06-2009, 08:34 PM
