29-03-2016 #26
Educational....
As i have ordered some cutters from a reputable supplier now, I asked them what the recommended cut specs were for rpm, chip load and feed. They instantly sent me a nice chart with it all on, feeding the data into HSMAdvisor shows up where i was probably going wrong a bit :)
Things alter rapidly when you give the calculator the correct data - i was running too fast, too deep, too much chip. Adjusted specs for a 2mm single-flute carbide would be...
18,000rpm
2.5mm DOC
600mm/min feed
I recall when i snapped the 2mm on the weekend I had it set at something like 1400mm feed and 5mm DOC :)
Helps having correct data i guess.
Beginner Moving Gantry Build? Read This!
By Tenson in forum Gantry/Router Machines & BuildingReplies: 3Last Post: 23-05-2018, 05:30 PM -
Garage CNC - A gantry style machine design
By fandango in forum Gantry/Router Machines & BuildingReplies: 14Last Post: 21-03-2014, 01:38 AM -
Truss style Gantry
By D.C. in forum Gantry/Router Machines & BuildingReplies: 28Last Post: 15-12-2012, 07:23 PM -
A few questions to start a DIY mini CNC
By purple_rob in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 03-08-2009, 11:08 PM -
Vertical moving gantry????
By Ross77 in forum Gantry/Router Machines & BuildingReplies: 9Last Post: 03-06-2009, 08:34 PM
