    If my understanding is better, after a good chat with the guy that supports HSM Advisor, it seems I might be a bit over zealous with the settings?
    Plugging numbers again, I get for the 2mm tool, 18,500 rpm, 1,200 mm/min feed, 0.5mm DOC and 0.065mm/t chip load.
    Reasoning - the limiting factors are the larger rads in the sharpened corners - this becomes slotting - also the manufacturers chip load limit of 0.065mm/t was set to not be exceeded, that gave DOC as 0.506mm as part of a balanced result to meet those factors.
    So my earlier run was 0.6mm - too deep, 23,000rpm - to fast, 450mm/min - too slow. It survived but took a long time and gave poor surface finish.
    The tool cannot give a 2.5mm DOC with any setting due to the slotting factor - the tool exceeds 100% torque limits = snapping - this backs up what really happened when i tried it.
    So it seems lighter, faster is a way forwards, might risk a tool and try it I think. Its more passes but travelling at 3 x the speed so should still be quicker.
  1. Beginner Moving Gantry Build? Read This!
    By Tenson in forum Gantry/Router Machines & Building
    Last Post: 23-05-2018, 05:30 PM
  2. Garage CNC - A gantry style machine design
    By fandango in forum Gantry/Router Machines & Building
    Last Post: 21-03-2014, 01:38 AM
  3. Truss style Gantry
    Last Post: 15-12-2012, 07:23 PM
  4. A few questions to start a DIY mini CNC
    By purple_rob in forum Gantry/Router Machines & Building
    Last Post: 03-08-2009, 11:08 PM
  5. Vertical moving gantry????
    By Ross77 in forum Gantry/Router Machines & Building
    Last Post: 03-06-2009, 08:34 PM
