    Quote Originally Posted by CharlieRam View Post
    Use a M00 at a convenient point, then press cycle start to continue, spindle stop might also be good at this point :)
    Yes but the finish cut is one continuous cut, you don't want an M00 in the middle of a continuous cut because you will not get another lead-out and lead-in so a tool mark is going to show, let alone stopping and starting the tool mid-cut will probably break it.
    Fitting clamps will mean working in the short space of time while the cutter is up the other end of the job, these parts are small so time is short and this is therefore dangerous. The Z axis mount is wider than the job so all clamps have to be low-profile <=10mm high or it means using a longer stick-out on the tool which again is not good on a 2mm cutter.
    These are difficult parts to make well but that does not mean they cannot be made ;)
    Hi Dave,
    I tend to use the tab method but this does leave a small witness mark (although the parts are just for me so that's ok). For customer parts I can understand why you are trying not to.
    So I think if I were to try the onion skin method I would skim the bed first then zero the end of the tool to the BED. Then MDI jog the Z axis up to 5.1mm (if the part is nominally 4.9-5.1 say) and then ZERO the DRO again.
    In your CAM you would than ask for a depth of 5.0mm. This would leave exactly 0.1mm of onion skin. This method is independent of the variation of part thickness.
    Thanks, that sounds a very similar method to Gerry's - using his "material height" DRO. I might have a go at skimming the bed and try that out.
    When I use the M00 I simply extend cut into scrap section past end of cut or put in a small loop and restart on a corner with change of direction and no signs of me doing so. think about it like cutting it on your manual mill overshoot on external long straightish edge to fascilitate later clamping, pause in scrap material on overshoot, add clamps to suit which could be pre mounted to swing over and clamp and carry on.
    Looking at your part, there are quite a few holes to screw into a spoil board so I would have the M00 after the holes were drilled to insert some screws to clamp the piece down, then just cycle start for the profile
    Hi
    yes there are some 3mm holes on one part and a couple of useful apertures but nothing at all on the second part, on the right in the picture, I can't add any holes either :(
    OK then, complete the outer profile, m00, remove waste outer profile, clamp right component leaving room for profile cut, cycle start and finish profile cut to separate parts. Easy :-)
    Ah, now that's interesting ;)
    So i would modify the drawing to make the outer edge of the two parts into a single path, then connect the inner edge of both parts into another solid path that overlaps the first path at each end, then as you say, run the small holes and the outer path to finish state and full depth, remove junk frame, add clamps to each part and run middle path to finish.
    I'm liking that, thanks. It means adding another two tool changes but thats not really relevant if it ensures the parts come off in top quality AND without any onion-skin to clean up.
    Nice.
    WooHoo! :)
    Thanks CharlieRam, your idea worked perfectly, best parts so far and a lot less stress on the nerves ;)
    I need to make some decent clamps etc but the extra tool changes were more than made up for with the time saved through not having much clean-up to do, just a quick run with a de-burrer and a little emery cloth.
  1. Beginner Moving Gantry Build? Read This!
    By Tenson in forum Gantry/Router Machines & Building
    Last Post: 23-05-2018, 05:30 PM
  2. Garage CNC - A gantry style machine design
    By fandango in forum Gantry/Router Machines & Building
    Last Post: 21-03-2014, 01:38 AM
  3. Truss style Gantry
    Last Post: 15-12-2012, 07:23 PM
  4. A few questions to start a DIY mini CNC
    By purple_rob in forum Gantry/Router Machines & Building
    Last Post: 03-08-2009, 11:08 PM
  5. Vertical moving gantry????
    By Ross77 in forum Gantry/Router Machines & Building
    Last Post: 03-06-2009, 08:34 PM
