    hi. I am having a few faults with my mill and wonder if someone out there can help. I am using the following software. to draw the part I am using solidworks and then importing to fusion 360 to make the g code. I check the drawing worksheet in fusion to make sure that the part is correct.
    then I download the g code to mach 3. but when I start milling on my little proxxon mf70 the part is 4 x larger. what am I doing wrong.
    michael
    Lives in Marple Stockport, United Kingdom. Last Activity: 11 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,347. Received thanks 620 times, giving thanks to others 89 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Quote Originally Posted by terry1956 View Post
    michael
    OK first does the machine move the correct distance from the commanded move ie zero you x axis and then send it a G0 X50 it should move exactly. 50mm
    Do this with the other axis. and report back.
    Does your machine move the correct distance when told to.? . . . You could have the Steps Per setting wrong.!
    Only other thing can think of is if you have entered a Scaling factor into Mach but you'd know this because the Scale would Falsh Yellow.
    Other than that without seeing the Cad model and G-code file can't really help.
    As i am not an expert i am not the best one to advice people, BUT check if you have any issues from mm to inches as 4 X 1 inch(2,54 cm)=10,16 cm. So may be a compbination of what Dean said ( scale factor X 10 ) and cm instead of inches or any program factor that converts inches to decimeters.
    Just an idea
    Vagelis
    The creative adult, is the child who survived
  1. Fusion 360 - best approach?
    By routercnc in forum Fusion 360
    Last Post: 18-06-2016, 07:49 AM
  2. When it all goes wrong
    By alboy in forum General Discussion
    Last Post: 12-12-2015, 01:16 AM
  3. What has gone wrong????
    Last Post: 05-09-2014, 12:25 AM
  4. Truss Structures - in larger gantry router design
    By CharlesJenkinson in forum Gantry/Router Machines & Building
    Last Post: 10-02-2014, 09:56 PM
  5. larger home made milling spindles - NMTB/ R8 taper?
    By jonnydeen in forum Tool & Tooling Technology
    Last Post: 13-09-2012, 11:17 AM
