Thread: CNC Vinyl Cutting
19-03-2016 #1
I have had the equipment for vinyl cutting for a while. Can anyone help with a source for the laminate materials please? Would like to make masks for airbrushing. Thanks in advance for any advice.
22-03-2016 #2
Buy some from ebay for testing, you'll usually get the info to buy direct with your shipment,
- Nick
22-03-2016 #3
Nick - Can I ask if you are using sticky back or laminated media.
24-03-2016 #4
I use masking vinyl, it's adhesive backed.
I also use a blast resist material for blast etching logos on parts, that's adhesive backed too.
Is there any point having a non-adhesive-backed vinyl for masking? Why would it be "laminated" and with what?
24-03-2016 #5
I use Aslan 85[?] masking film, I buy it from Dorotape.
The Following User Says Thank You to graffian For This Useful Post:
24-03-2016 #6
Graffian - Many thanks. I ordered a little to try.
24-03-2016 #7
Aslan 85 is an water-based-adhesive backed PVC film, it's not a laminate ;-)
24-03-2016 #8
Nick - I will tell it that as peel the backing off!
24-03-2016 #9
24-03-2016 #10
Check out a company named Hexis at www.Hexis.co.uk. In the world of self adhesive vinyl the thinner it is the more expensive it is as it sticks better and conforms to curves easier. There are a number of film specifically for paint masking and sand blasting. The masking material has an easy peel adhesive and is usually known as applimask or polymask. If you only want to do light surface etch sandblasting then the cheapest black or white vinyl film is very usable but if you want to cut deeper then you will need proper sandblast material that is almost like a thin silicone rubber but your machine will need a new sharp blade and plenty of pressure.
Walnut Vinyl Wrap - Good one?
By Tenson in forum General DiscussionReplies: 10Last Post: 29-12-2014, 02:53 PM -
Cutting Ply/MDF
By Leadhead in forum Wood Finishing Tips & TricksReplies: 3Last Post: 02-10-2013, 01:59 PM -
Cutting Fluid
By Web Goblin in forum Swarf & Chip ManagementReplies: 4Last Post: 12-01-2013, 09:31 PM -
The cutting fun begins
By m.marino in forum Machine DiscussionReplies: 2Last Post: 01-04-2012, 12:35 AM -
Test of new vinyl cutter
By evildrome in forum Tool & Tooling TechnologyReplies: 0Last Post: 17-01-2011, 12:25 AM
