There are no Negative Z axis moves in that G-code so it will not cut anything using the way you set it up. It certainly shouldn't plunge down.?
Have you cut anything with machine before.? It could be that Mach3 is setup wrong regards the Steps per setting so it's moving further than it's being commanded.?
19-07-2016 #2
Just an idea - when my machine starts any job posted from Fusion 360 it does a full retract to the machine's Z axis zero point i.e. full retract to the "up" limit and then continues the job. Its not going to the stock or work zero for Z axis. This is a "safety" feature I think in the Fusion 360 post in order to ensure the work piece is cleared from whatever starting position your tool is at.
Sounds like you may have your machine set up so that its Z axis machine zero is either at the top of the work piece or on the bed and the full retract my machine is performing is a "full down" to the bed move (machine zero) on your machine before continuing.
Hope that helps.Last edited by Washout; 19-07-2016 at 10:01 AM.
My CNC Projects: https://www.youtube.com/imadethisoncnc
Fusion 360 - best approach?
By routercnc in forum Fusion 360Replies: 10Last Post: 18-06-2016, 07:49 AM -
First go at Fusion 360 Adaptive Clearing
By Washout in forum Fusion 360Replies: 0Last Post: 15-10-2015, 07:52 PM -
Fusion 360 - full, free 3D CAD and CAM.
By Leadhead in forum Fusion 360Replies: 5Last Post: 24-06-2015, 11:31 PM -
Cambium Code Web Tools – Parametric G-code Generation
By CambiumMachines in forum Manufacturer NewsReplies: 0Last Post: 09-01-2013, 04:56 AM -
Super X1 conversion - CNC Fusion kit
By bruce_miranda in forum Sieg Milling MachinesReplies: 12Last Post: 19-09-2008, 01:43 PM
