    Quote Originally Posted by d4cnc View Post
    Is the right thing to do, choose 2d contours in HSMexpress and use a 2mm bit to cut everything? Or is drilling more recommended?* I suppose if possible I'd prefer less tool changes rather than actually speed..*
    Use the largest tool you can get away with. If not too many holes then you can use the end mill and either pocket the holes or use peck drilling cycle.
    If lots of holes then using a drill will be quicker.
    Thanks for advice.. is there a general rule of thumb for what diameter cutter for pocketing a hole.. obviously a 3.5mm cutter in a 3.5mm hole would just be plunging and wouldn't be able to spiral in..
    Whereas a smaller bit can spiral in better.
    Or is straight down plunging not too much of a problem in 3mm thick aluminium with a single flute cutter? So a 3mm cutter in a 3.5mm hole would be fine to pocket.
    Well you'd normaly use tool just little smaller than hole if spirling down. So in this case 3mm tool would work well. But if just 1 or 2 holes then using same size tool and peck drilling cycle with small peck amount is quicker.
  1. Milling Sheet Aluminium
    By p1lts in forum Metalwork Discussion
    Last Post: 08-03-2014, 12:23 AM
  2. WANTED: 100mmx100mm 6mm aluminium plate/sheet.
    By Isaac in forum Items Wanted
    Last Post: 06-02-2014, 12:11 AM
  3. FOR SALE: Aluminium Tooling Sheet - Various sizes
    By Fewco in forum Items For Sale
    Last Post: 16-01-2013, 04:27 PM
  4. Drill 4 x 28mm holes through 44mm thick aluminium
    By WandrinAndy in forum Gantry/Router Machines & Building
    Last Post: 30-09-2012, 09:17 AM
  5. Need to cut .5 Aluminium Sheet - Set-up Needed
    By Andrew in forum Metal Finishing Techniques
    Last Post: 15-08-2010, 04:12 PM
