    So much for a day off only ended up working till 9pm, had to plug it in a try it when I got back, spindle fine, Z axis fine, Y axis with A slaved no problem, X axis just a rumble and rock from motor, too tired to even think about it tonight can't be too serious it didn't go bang! The two working axis have proved already it has all the speed I will ever be able to use in the flat and then some if it lived in a shed the shed would have been rocking. Would have been nice to have it all work but 4 from 5 is better than a kick up the backside.
    Quote Originally Posted by lucan07 View Post
    Nm your not the only one as I've had to sit around not doing much today too :(.
    Early start in the morning? Post a video of her jogging about with a big cheesy grin of joy? Go on spoil me you know you want to
    Will you share with me where you got your spindle and VFD from, that is a good price maybe I was looking in the wrong place but I was seeing £300 for the 2.2's...
    No problem Lee Fleebay had a 20% off everything offer for a few hours on 6th or 7th of April so I grabbed the VFD and spindle then, full price is £182 ans I got £36 discounted. Still has original offer ships from Germany about 5 days.
    http://www.ebay.co.uk/itm/2817523492...%3AMEBIDX%3AIT
    I have set up cooling in a 25ltr can of distilled\deionised water removed 10 ltr and added 5ltr of Mono Propylene Glycol to prevent any algae etc, Trying a new idea with pump though a minature 8.5w with 10ft lift seems to be ideal and totally silent.
    http://www.ebay.co.uk/itm/3913989923...%3AMEBIDX%3AIT
    Great thing is fits into can easily so drill three holes in cap 2x9mm for hose and 1x3mm for cable drop pump in and screw on cap sealed unit, return pipe above water and only noise is the trickle of water from the set up if you listen carefully.
    Will post some video as soon as last motor sorted while tuning Y and slaved A tweaking it up, at 5m pm with 2000 accel the whole thing began to walk/run accross the room quite a weight on gantry, so I am going to have to machine either keys or flats or get some decent resin to lock timing pulleys securely, I've tapped 2 x 4mm grub screws into each pulley but would not trust them to hold at the speeds it was moving especially on round end of Ballscrew. I can't see torque or speed being a problem apart from trying to tear my hard work to pieces if I push it to hard.
    Another bargain I found may be of interest was the spindle mount under £20 delivered from HongKong and it arrived in 6 days was thinking about machining a large bearing mount but at that price not worth while.
    http://www.ebay.co.uk/itm/1317724808...%3AMEBIDX%3AIT
  4. The Following User Says Thank You to lucan07 For This Useful Post:
  5. #4
    Been thinking about my pulleys and how to secure them over breakfast, it may be obvious that I have little or no engineering experience so is this an acceptable way to lock pulleys securely.
    My problem:
    Each pulley is drilled and tapped and fitted with opposing 4mm grub screws, but motor and ballscrew shafts to which they are mounted are both round so not an ideal situation and I sure they would eventually move at some point.
    My intended solution:
    To drill into the pulley and shaft from the end effectively making a semi circular keyway into which I can insert a pin, I am thinking that 2-3mm drill giving 1-1.5mm semi circular key slot in both shaft and pulley would be enough to lock these connections and prevent slippage.
    I know keyways tend to be slotted and have vertical sides, but as an amateur who did not consider the amounts of torque involved moving weight at speed
    a) is my solution viable?
    b) is 2mm or 3mm with a steel pin sufficient to do job?
    c) is there a simpler way I haven't considered?
  6. #5
    From my understanding the screws should be at 90' to each other also if you clip a little bit of copper wire off and flatten it then slip it down the grub screw hole it will grip the shaft better.
    Loctite will also hold them on.
  7. The Following User Says Thank You to Clive S For This Useful Post:
  8. #6
    Lives in Plymouth, United Kingdom. Last Activity: 3 Hours Ago Has a total post count of 1,747. Received thanks 298 times, giving thanks to others 11 times.
    Drilling into the end, cutting both shaft and pulley, is an established technique but you will find it difficult to do accurately with an aluminium pulley as the drill will start to wander. Also, it's a mistake to drill for grub screws at opposite sides. You are now balancing the force of one grub screw against the other. Much better to drill at 90-120 deg apart, so both grub screws and the bore of the pulley grab the shaft. That might give some useful extra grip. You could just file a small flat on the shaft for one grub screw to bear against?
    Good luck - I haven't reached this point on my own machine yet!
  9. #7
    The pulleys are not aluminium they are Zync plated steel quite solid so I may try a test on the end of one ballscrew I have a small drill stand that I use for holding a tapping aid that I can fix in place with Lube ands patience it should be possible without to much wandering.
  10. #8
    Drilling in from the end is a good method, if at all possible, drill in and tap a thread - M3 or 4, then fit grubscrews, that way the pulley is secured both directions - axially and radially. You will only get away with it if both metals are similar hardness, my concern is the hardened end of the screw - if one is softer the drill will wander into it.
    And yes, grubscrews at 90 or 120 degrees only, never opposite and only two screws, always file/grind a flat on the shaft for at least one screw, better still drill a little divot the same size as the tip of the screw.
  11. #9
    Got ten minutes to inspect the plug on X axis and it had a problem caused by old age and drugs, I got older massive doses of steroids prescribed eyesight went to crap, some plonker managed to rotate pins by 90% when soldering late the other night, easily fixed glad I didn't use a 6560 for this build the driver would have gone pop and I would be soldering a new TB6560AHQ IC into the board and tales of magic smoke would be told.
  12. #10
    Bit of progress made over the weekend sorry to say weather was nice so my bikes took most of my free time been neglecting them too much lately they need riding and I need the exercise getting old, London Surrey 100 end of July and Box and Neath hills are both killers if you are out of shape and practice. However fixed problem of slipping pulleys before it occured, a bit of testing/tuning first cuts a few slats of 25mm mdf which I have decided to use for first sacrificial bed, had a selection of 2020 off cuts laying around from printer builds etc so using these for clamping t-slots gives me 5mm to skim as needed. Using 6mm Router bit 1st DOC 3mm 2nd 6mm 3rd 12mm MDF using 12000rpm and 1500mm pm feed no problems with cuts. I have used a BOB I was given I think its a cheap chinese import and I appear to be having occasional problems, axis will refuse to operate in one direction, jogging a different axis then frees the original axis to move as required so another BOB on its way, double checking wiring next on to do list, all wiring is CY shielded cable currently all mounted in small pc tower case whilst waiting for cabinet to arrive so may just be everything to close for comfort. VFD is mounted well away from everthing else.
  1. Large Format Steel Framed Router
    By nathandavies in forum Gantry/Router Machines & Building
    Last Post: 07-02-2016, 02:51 PM
  2. Advice on Mammoth CNC Router Build - Steel Framed - 2440mm x 1220mm cutting area!
    By Wejjmeister in forum Gantry/Router Machines & Building
    Last Post: 03-01-2016, 12:45 AM
  3. BUILD LOG: Steel Framed CNC router
    By Joe in forum DIY Router Build Logs
    Last Post: 23-06-2013, 10:45 PM
  4. BUILD LOG: Steel Framed Router
    Last Post: 14-09-2011, 06:51 PM
  5. BUILD LOG: My steel framed router
    By pavlo in forum DIY Router Build Logs
    Last Post: 06-03-2011, 10:08 PM
