Thread: Vacuum Suction Bed
22-03-2016 #1
I am currently assisting work colleagues on our 4 CNC routers regarding the vacuum pump.
I am using a pacer HDS 25/12 and literally just use the vac pump and masking tape to secure my material down.
The trials on the other machines are not as successful as to how i have operated my router for years.
We mainly use Aluminium from 0.8mm to 6mm thick and having to screw each sheet down (which i know is the stone-age).
I have trialled VillMill which is supposed to lay under your sheet material and with he friction from the router cutter heat up enough to stick the parts down to the bed.
The idea of this is to eliminate using any tags at all and also stop having to screw material down.
Are there any other ideas i can try to perhaps get better suction or enable to eliminate using tags.
Daniel
DIY Vacuum Fixtures
By Boyan Silyavski in forum Tool & Tooling TechnologyReplies: 32Last Post: 27-09-2016, 01:25 PM -
Making a Vacuum Bag
By Tenson in forum General DiscussionReplies: 18Last Post: 02-04-2016, 11:08 PM -
Need More Suction on the extraction
By adamh in forum Dust Extraction & CollectionReplies: 4Last Post: 02-07-2014, 10:37 PM -
I want a vacuum table!
By Tenson in forum Machine DiscussionReplies: 44Last Post: 08-01-2014, 07:40 PM -
eBay: 2 Vacuum Pumps, Vaccum Motors, 3phase 5.5HP, CNC Bed, suction
By kingcreaky in forum Items On eBay UKReplies: 0Last Post: 18-07-2013, 03:20 PM
