Thread: Tool Changing
Possibly a well too many times asked question but my searches only bring up the talk of scripts so please bear with me!
My g-code wanted a tool change so I swapped the tool, went back to the workpiece surface and zeroed the Z axis - restarted Mach3 and the machine went off and started 'cutting' above the surface.
Was my method correct or am I just imagining it should be easier than it is??
Cheers!
	23-03-2016 #2
Your method is correct.
Provided you did Zero Z axis and the G-code is correct. Only thing I can think of that would cause this is if you have a tool offset applied in the tool table for that tool #. If your not using spindle with tool holders then all tools in the tool table should be zero.
	23-03-2016 #3
Cheers Jazz, I'm not using a tool table or anything like that - just a plain manual swap by hand and 2 x adjustable spanners. My bits are of different lengths. At least I know the problem isn't with me!
	23-03-2016 #4
I have had this when playing with some preinstalled tools in a CAM program.
you will need to look through your gcode for the tool length offset call G43 H~ and delete it. Do not delete the M6 call as this is what stops the machine.
If you ever rig up a tool measuring probe and use Mach3 then it is worth looking up Ger21's mach2010 screenset. makes zeroing tool after tool swaps a doddlehttps://emvioeng.com
The Following User Says Thank You to komatias For This Useful Post:
	23-03-2016 #5
Need guidance on manual tool changing best practice (and other things)
By Noplace in forum Machine DiscussionReplies: 2Last Post: 07-12-2015, 11:03 AM -
Spindle tool changing.
By D-man in forum Tool & Tooling TechnologyReplies: 12Last Post: 02-09-2014, 09:36 AM -
DXF with tool offset
By Cube3 in forum CAD & CAM SoftwareReplies: 4Last Post: 25-03-2014, 10:54 PM -
Changing folder permissions
By motoxy in forum Computer SoftwareReplies: 7Last Post: 04-02-2012, 11:28 PM -
What tool would you use for this?
By Kai in forum Tool & Tooling TechnologyReplies: 1Last Post: 21-03-2011, 06:08 PM
