Page 2 of 2 FirstFirst 12
    If the key locates after insertion it should not overtighten locking the mechanism beyond the point you leave it, I pesume it has been designed to act in this manner, presumable the chuck operated the taper when working and threads etc would have been worked to locate and lock if a professional design
    Lives in East Lothian, United Kingdom. Last Activity: 10 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    Lucan, no offence, but your suggestion won't work.
    Tapers rely on being firmly held together. With your suggestion, you would either have to ensure the tapers never fully tightened, meaning the toolholder will be loose and rattle in the spindle, or risk never being able to get the key in.
    If the key is sprung it would be designed to act at a point to stop overtightening as well as aligning the thread to start at a specific it would only engage at a point beyond just beyond correct torque when milling, presumably you release it to with the chuck to undo otherwise it would engage and lock once on each rotation.
    Rabs's Avatar
    Lives in Bedford, United Kingdom. Last Activity: 05-08-2016 Has been a member for 9-10 years. Has a total post count of 22.
    Quote Originally Posted by lucan07 View Post
    I think m_c's point is that the toolholder can't be tight against the key and the taper at the same time - it has to hit one of them first. If you want that to the key to stop over tightening, then itwon't be tight on the taper. If it isn't tight on the taper then the tool will wobble. Thanks for taking the time to help though - there might well be something there related to keyways. I'll give it some thought.
    Quote Originally Posted by m_c
    Big lathes, the tapers never turn against each other. They're secured using either bolts, or a retaining nut.
    The only small lathes I've seen with screw on chucks, use locating registers, not tapers.
    Ok, that makes sense. I suppose the smaller angle the taper the more prone it will be to locking because the larger the radial force is for a given axial bolt tension. That also explains why a lathe chuck with a flat register (which I suppose can be considered as a 180 degree 'taper') is much less prone to locking.
    If it makes any difference this is a small machine with a 1/2hp spindle motor.
  5. #15
    Questions,
    In Fig 2 what is the diameter to the thing spindle part, the bit that holds the pulley.
    What is the biggest tool you would be satisfied using ? Be reasonable here.
    Any pictures as opposed to blocky diagrams.
    John S -
  6. #16
    Rabs's Avatar
    Questions,
    Here you go. The spindle block is enclosed, with all bearings and pulleys concealed. At the top there is only an 18mm diameter shaft protruding. Ignore the bit of aluminium extrusion, it's just a temporary mount for a spindle speed sensor.
Name:	2016-03-25 16.39.20.jpg
ID:	18022Click image for larger version.
Name:	2016-03-25 16.39.25.jpg
    At the nose the spindle is 40mm in diameter
Name:	2016-03-25 16.39.34.jpg
    Here is the easychange chuck. To secure it you push a bolt from below, through the hole in the narrow end of the chuck and into a thread on the spindle. (see original post)
Name:	2016-03-25 16.40.22.jpg
ID:	18025Click image for larger version.
Name:	2016-03-25 16.40.30.jpg
ID:	18026Click image for larger version.
Name:	2016-03-25 16.40.32.jpg
    Here is one of the easychange toolholders:
Name:	2016-03-25 16.40.40.jpg
    And here's what the setup looks like as I received it:
Name:	2016-03-25 16.44.59.jpg
    Here is a tooholder I've knocked up with a stud at the top and how it looks screwed directly into the spindle. I've not used this yet on the back of m_c's warning.
Name:	2016-03-25 16.40.51.jpg
ID:	18029Click image for larger version.
Name:	2016-03-25 16.43.09.jpg
    I've made it with drive slots to fit the easychgange chuck but these could also be used for a spanner to release it from the spindle, with a normal spanner used on the flats at the top of the spindle.
  7. #17
    It's the Coventry Easy Change system, I have the same on my bench top CNC mill, it locks up nice and tight and works very well, check all the internal and external tapers for damage.
    I rarely use tooling bigger than 10mm, carbide tooling and High Speed Machining feeds, speeds & DOC are the order of the day,
    - Nick
  8. #18
    Is it just the light/reflections, or is the taper on that toolholder look like somebody's sanded/filed it?
    I've got the easy change system on bench top mill, and my holders all lock in that tight, I usually have to use a screwdriver to break them away from the taper to get them out.
    Could it be the ratchet mechanisms not working correctly?
    I'd perhaps give Coventry a phone, and see what they say. It could be as simple as the spindle adapter needing stripped and cleaned, although I have no idea how they separate.
    Contact details can be found on the Coventry Engineering website - http://www.coveng.co.uk/group/covent...sy-change.html
  9. #19
    Rabs's Avatar
    OK, thanks guys. I'll give it all a good clean and check over before doing anything drastic. Maybe the locking mechanism just has some swarf in in.
    If you mean the toolholder with the threaded stud at the top. It looks rough because I've just rough turned it to check the principle. I was intending to grind and harden the taper before using it in anger.
  10. #20
    Rabs's Avatar
    So, it turns out that the looseness wasn't actually in the easychange chuck or the toolholders but in the spindle itself. Thanks for your help everyone. I'll start a new thread with a question on what to do next.
  1. WANTED: Boxford 190VMC toolholders, tool changer and manuals
    By davethesteam in forum Items Wanted
    Last Post: 06-11-2017, 11:29 AM
  2. FOR SALE: Homemade 'Coventry' Type Easy Change Toolholders
    By jamesgates1000 in forum Items For Sale
    Last Post: 04-12-2015, 09:22 PM
