    Rabs's Avatar
    Lives in Bedford, United Kingdom. Last Activity: 05-08-2016 Has been a member for 9-10 years. Has a total post count of 22.
    Questions,
    In Fig 2 what is the diameter to the thing spindle part, the bit that holds the pulley.
    What is the biggest tool you would be satisfied using ? Be reasonable here.
    Any pictures as opposed to blocky diagrams.
    Here you go. The spindle block is enclosed, with all bearings and pulleys concealed. At the top there is only an 18mm diameter shaft protruding. Ignore the bit of aluminium extrusion, it's just a temporary mount for a spindle speed sensor.
Name:	2016-03-25 16.39.20.jpg
ID:	18022Click image for larger version.
Name:	2016-03-25 16.39.25.jpg
    At the nose the spindle is 40mm in diameter
Name:	2016-03-25 16.39.34.jpg
    Here is the easychange chuck. To secure it you push a bolt from below, through the hole in the narrow end of the chuck and into a thread on the spindle. (see original post)
Name:	2016-03-25 16.40.22.jpg
ID:	18025Click image for larger version.
Name:	2016-03-25 16.40.30.jpg
ID:	18026Click image for larger version.
Name:	2016-03-25 16.40.32.jpg
    Here is one of the easychange toolholders:
Name:	2016-03-25 16.40.40.jpg
    And here's what the setup looks like as I received it:
Name:	2016-03-25 16.44.59.jpg
    Here is a tooholder I've knocked up with a stud at the top and how it looks screwed directly into the spindle. I've not used this yet on the back of m_c's warning.
Name:	2016-03-25 16.40.51.jpg
ID:	18029Click image for larger version.
Name:	2016-03-25 16.43.09.jpg
    I've made it with drive slots to fit the easychgange chuck but these could also be used for a spanner to release it from the spindle, with a normal spanner used on the flats at the top of the spindle.
    It's the Coventry Easy Change system, I have the same on my bench top CNC mill, it locks up nice and tight and works very well, check all the internal and external tapers for damage.
    I rarely use tooling bigger than 10mm, carbide tooling and High Speed Machining feeds, speeds & DOC are the order of the day,
    - Nick
    Lives in East Lothian, United Kingdom. Last Activity: 8 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    Is it just the light/reflections, or is the taper on that toolholder look like somebody's sanded/filed it?
    I've got the easy change system on bench top mill, and my holders all lock in that tight, I usually have to use a screwdriver to break them away from the taper to get them out.
    Could it be the ratchet mechanisms not working correctly?
    I'd perhaps give Coventry a phone, and see what they say. It could be as simple as the spindle adapter needing stripped and cleaned, although I have no idea how they separate.
    Contact details can be found on the Coventry Engineering website - http://www.coveng.co.uk/group/covent...sy-change.html
    Rabs's Avatar
    OK, thanks guys. I'll give it all a good clean and check over before doing anything drastic. Maybe the locking mechanism just has some swarf in in.
    If you mean the toolholder with the threaded stud at the top. It looks rough because I've just rough turned it to check the principle. I was intending to grind and harden the taper before using it in anger.
    Rabs's Avatar
    So, it turns out that the looseness wasn't actually in the easychange chuck or the toolholders but in the spindle itself. Thanks for your help everyone. I'll start a new thread with a question on what to do next.
  1. WANTED: Boxford 190VMC toolholders, tool changer and manuals
    By davethesteam in forum Items Wanted
    Last Post: 06-11-2017, 11:29 AM
  2. FOR SALE: Homemade 'Coventry' Type Easy Change Toolholders
    By jamesgates1000 in forum Items For Sale
    Last Post: 04-12-2015, 09:22 PM
