Thread: Mach3 VFD PWM signal...
Its a cnc4you CP 0-10v breakout board with on-board converter.
I fired the question at cnc4you and just got a reply - yes i should be able to measure 0-10v there, so i have no idea why i cannot.
26-03-2016 #2
Make sure you don't have the lead plugged into the current connectors marked "A" or "mA" - For voltage they should be plugged into "COM" and "V". Its very easy to forget.
Graeme
26-03-2016 #4
Thanks guys,
Definitely on the volts, this meter only has three sockets - V/mA, Com, 10A and i only used the Com and V/mA ones 99% of the time.
I can't see lead capacitance having any effect here, surely it should be a measurable 0 to 10v Dc signal going to the VFD?
I know 4-20mA can be a pain to measure sometimes unless its loaded properly but 0-10v?
26-03-2016 #5
26-03-2016 #6
Bugger, sounds about right for my luck.
But then how the heck does it manage to work at all?
Might be worth putting the 'scope on it?
27-03-2016 #8
I think he meant a proctoscope
27-03-2016 #10
No I meant a proctoscope ! Happy Easter Clive..
Serious suggestion now - If you have an analogue meter these can have impedances as low as 5000 ohms per volt. All electrical measuring devices draw current from the circuit and this affects the circuit (experts can get precious here, but I am simplifying !). Having said that, I would not expect the BoB to be such a high impedance source as to have a drastic voltage drop when meter is put on it.
As Jazz says, it could be a dodgy Bob. I have never met a Dodgy Bob, but I do know a bloke called Dodgy Dave.Last edited by cropwell; 27-03-2016 at 02:03 PM.
Stepper motor Pulse Signal Generator module
By Tom J in forum Motor Drivers & ControllersReplies: 8Last Post: 12-01-2016, 11:47 AM -
AM882 Alarm and Enable Signal Question
By Gotty101 in forum Motor Drivers & ControllersReplies: 2Last Post: 24-11-2015, 11:07 PM -
Need to slow down a signal due to Safe Torque Off alarm
By corkcnc in forum General ElectronicsReplies: 0Last Post: 04-06-2014, 11:35 PM -
Encoder Signal to PC
By antsals in forum General ElectronicsReplies: 6Last Post: 26-04-2011, 10:49 AM -
+5V TTL Signal
By NC-Joey in forum General ElectronicsReplies: 2Last Post: 12-08-2007, 02:46 PM
. But good point. Dave: By capacitance I meant from the leads they act as a capacitor if they are very close.
