    I think he meant a proctoscope
    Lives in Marple Stockport, United Kingdom. Last Activity: 11 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,345. Received thanks 618 times, giving thanks to others 87 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    I think you meant a endoscope
    No I meant a proctoscope ! Happy Easter Clive..
    Serious suggestion now - If you have an analogue meter these can have impedances as low as 5000 ohms per volt. All electrical measuring devices draw current from the circuit and this affects the circuit (experts can get precious here, but I am simplifying !). Having said that, I would not expect the BoB to be such a high impedance source as to have a drastic voltage drop when meter is put on it.
    As Jazz says, it could be a dodgy Bob. I have never met a Dodgy Bob, but I do know a bloke called Dodgy Dave.
    Yep happy Easter Rob I was just jesting Avo 7 days and valve volt meters.
    LOL:)
    Anyways, I disconnected the BOB from the VFD and I can get sensible measurements from 0 - 10v so it seems the BOB is fine, the output is not linear though.
    When connected to the VFD, no voltage again and the motor stops as soon as the meter is connected.
    Very odd.
    I did make a lookup table of speeds so I can easily set what i really want even though its not what it displays.
    If you only use a few speeds to cover your jobs I wonder if a relay module board with each relay connected to a trim pot and resistor pair from a 10v supply (each of which was fine tuned to give the right volts for that speed) could be used?
    I guess you would need a gcode command in the code to switch the right relay on instead of the speed command. Just a different take on it.
    I have done a similar thing at work with an awkward interface for a temperature controller - works well.
    It used a 10 channel bargraph chip to take a 0-10v signal and convert to 10 adjustable resistance outputs using 10 miniature relays and 10 trim-pots - the relays were needed to give isolation.
    trouble with using Mach it would need multiple outputs to do it directly and thats not so easy.
    The bargraph / relay / pot system would work though - it just converts 0-10v variable into 0-10v stepped signals.
    I think the lookup table will work for now until a proper fix comes up.
    I see we have 15 spindle pulleys - could they be set up to do this?
    I'm not sure the ratio does anything when using PWM though.
  1. Stepper motor Pulse Signal Generator module
    By Tom J in forum Motor Drivers & Controllers
    Last Post: 12-01-2016, 11:47 AM
  2. AM882 Alarm and Enable Signal Question
    By Gotty101 in forum Motor Drivers & Controllers
    Last Post: 24-11-2015, 11:07 PM
  3. Need to slow down a signal due to Safe Torque Off alarm
    By corkcnc in forum General Electronics
    Last Post: 04-06-2014, 11:35 PM
  4. Encoder Signal to PC
    By antsals in forum General Electronics
    Last Post: 26-04-2011, 10:49 AM
  5. +5V TTL Signal
    By NC-Joey in forum General Electronics
    Last Post: 12-08-2007, 02:46 PM
