Thread: Speeds and feeds
Pretty new to this but I have been machining Acrylic on converted Sieg X1 mill between 1500 -2000 rpm DOC 1mm FR 1200mm/min 6mm 2 flute and getting good results for welding with Dichloromethane faster RPM than this I was starting to have problems with heat softening the Acrylic as cutting without any cooling. I set it running in Mach 3 and adjusted on the fly for first couple of cuts testing the limits, then went with it. 2 flute performed better than 4 flute for me.
26-03-2016 #2
Thank you guys for your replies !
Today I took my first cuts and the machine is currently slotting the sploiboard :) Running at 10000 RPM and a FR of 950mm/min. Chips are perfect, and there is a little bit of smoke when the bit does its first pass because of the MDF surface. Otherwise, it's looking great ! I will have to sand it a little bit when i'm done. So far, the slots are being cut. Second operation is the T slotting. I'll post pictures when I'm done. I had to cheat a little bit for the GCode in Masterdom because I had to draw the part bigger than what it really is so I could make pockets for the slots.
I also went to the store and bought a dry/wet vacuum cleaner, because things are getting messy haha. Gotta make that dust shoe when I get my 3d printer !
Feeds and speeds software
By suesi34e in forum Swarf & Chip ManagementReplies: 4Last Post: 22-03-2016, 10:30 PM -
Feeds and speeds software?
By Leadhead in forum Computer SoftwareReplies: 9Last Post: 31-10-2015, 09:34 PM -
Feeds and speeds
By dudz in forum Tool & Tooling TechnologyReplies: 0Last Post: 26-08-2013, 11:42 AM -
Advice needed on feeds and speeds!
By lateAtNight in forum Machine DiscussionReplies: 5Last Post: 14-11-2012, 12:47 PM -
Speeds and Feeds
By Web Goblin in forum Tool & Tooling TechnologyReplies: 0Last Post: 20-09-2012, 01:38 PM
