Thread: machine stops when homing
26-03-2016 #3
Hi Dean,
I only had an hour today so didn't get to try out many options including PC re-boot. The switch did have bits of swarf around it so could be that. It's been on that machine for a while so maybe it's starting to play up.
I'll see if it is OK next time I fire up the PC. I'll also try a new switch and give the terminal connectors a bit of a squeeze before sliding them onto the switch again to get a tight electrical joint.
Problem with homing
By Andyman in forum Gantry/Router Machines & BuildingReplies: 4Last Post: 22-03-2016, 07:56 PM -
Best place for hard stops?
By mitchejc in forum Gantry/Router Machines & BuildingReplies: 4Last Post: 25-11-2014, 06:39 AM -
gcode stops mid way can anyone test..
By crossleymarko in forum CAD & CAM SoftwareReplies: 16Last Post: 22-04-2012, 12:45 AM -
homing problems in mach3
By johngoodrich in forum Artsoft Mach (3 & 4)Replies: 2Last Post: 17-09-2011, 08:28 PM -
Homing Switches
By m_c in forum General ElectronicsReplies: 3Last Post: 04-11-2010, 11:21 PM
