Thread: machine stops when homing
27-03-2016 #8
I used to use proximity sensors on 24V straight into the pin on the cheapo BOBs There is a 10K R inside a lot of them so it should only put about 2.4mA into the BOB you can check this by putting your meter on mA range and connecting between the black wire sensor and ground. and see what current it draws. (at your own risk of course)
Problem with homing
By Andyman in forum Gantry/Router Machines & BuildingReplies: 4Last Post: 22-03-2016, 07:56 PM -
Best place for hard stops?
By mitchejc in forum Gantry/Router Machines & BuildingReplies: 4Last Post: 25-11-2014, 06:39 AM -
gcode stops mid way can anyone test..
By crossleymarko in forum CAD & CAM SoftwareReplies: 16Last Post: 22-04-2012, 12:45 AM -
homing problems in mach3
By johngoodrich in forum Artsoft Mach (3 & 4)Replies: 2Last Post: 17-09-2011, 08:28 PM -
Homing Switches
By m_c in forum General ElectronicsReplies: 3Last Post: 04-11-2010, 11:21 PM
