Thread: VFD for drill press
30-03-2016 #6
I mentioned to a colleague that changing belts on my drill press was a bit of a pain and he said some people had used Sturmey Archer bike hub gears instead of the pulleys and can then change to lots of speeds. They are pretty strong to take the pedalling loads. Then you just have a lever on the side of the machine to select the gear.
Or some of the fancy drill presses have a pair of cones to give a range of continuously variable speeds without even stopping the machine. Again sliding a lever selects the speed. Probably an expensive option though?
WANTED: Drill press
By D-man in forum Items WantedReplies: 0Last Post: 30-08-2013, 07:45 AM -
RFQ: Press cost question ?
By Fivetide in forum Projects, Jobs & RequestsReplies: 8Last Post: 01-12-2012, 08:26 AM -
Bearing interference fit / press fit
By Mad Professor in forum General DiscussionReplies: 5Last Post: 30-09-2012, 11:26 PM -
Does such a beast exist (using Z plane as manual-esque drill press)
By HankMcSpank in forum Computer SoftwareReplies: 0Last Post: 04-03-2010, 05:36 PM
