Thread: Looking to Buy a CNC Machine
31-03-2016 #1
Hello My name is Carlos and I looking to buy a CNC Router Engraving Machine 3040T 3th Axis to use to make 1/2 inch thick wooden letters for my business about 11inch high and 9in in width just wanted to know if this is a good machine to use.
31-03-2016 #3
Hola Carlos,
As Clive says, dont bother. If it is just cutting out letters you want, then it is better to get a laser cutter with around 80W for the 1/2" thick ply. If you cut pine, then you should be able to cut 1/2" with 50W.
I have a 3040T and would not use it for anything apart from engraving plastics. There are versions with a water cooled spindle but these are let down by the rest of the machine.
Regardshttps://emvioeng.com
31-03-2016 #4
Thank you for the feed back, and my budget isn't much because I don't want to put to much into the machine just yet and it doesn't do what I need it to do.
01-04-2016 #5
Question for you komatias I have seen a few videos of the 3040t cutting and it cuts metal very well don't see why it cant or wont cut wood like I need it to in fact the company that I have ordered letters from uses a similar machine
LIMAC knife cutting machine and plasma machine, cnc router latest video
By therouterlady in forum Manufacturer NewsReplies: 0Last Post: 18-09-2013, 05:28 AM
