Thread: Engraving bits...
30-03-2016 #2
3mm shank? They are good for fine engraving, and as you suspect shallow cuts, for aluminium I run them at 28800rpm with air for cooling and to clear chips with the occasional squirt of lube.
I use HSM advisor for feeds & speeds, the carbide points aren't in the least bit forgiving if you plough in a bit deep or don't have the rpm to keep the chips thin enough,
- Nick
A few MDF bits
By D-man in forum Woodworking Project ShowcaseReplies: 14Last Post: 18-01-2026, 02:11 PM -
Small 3D Engraving
By magicniner in forum General DiscussionReplies: 2Last Post: 01-01-2015, 10:46 AM -
NEW MEMBER: engraving
By pontinal in forum New Member IntroductionsReplies: 3Last Post: 11-05-2012, 01:02 PM -
How would I go about making a jig to grind carbide V cutter/engraving bits?
By HankMcSpank in forum Tool & Tooling TechnologyReplies: 2Last Post: 12-03-2012, 12:39 AM -
PCB Engraving / Cutting
By jrob3rts in forum General DiscussionReplies: 6Last Post: 02-06-2011, 09:35 PM
