    Hi All,
    I have been working in an engineering environment for 24 years, mainly in machining and build areas but I've recently started using 3D CAD and have designed a few products.
    My new focus is on designing a 3 axis cnc router with a 4' square bed.
    So my aim in joining this forum is to learn as much as i can and hopefully gain advice and knowledge from those that are on here.
    Thanks in advance.
    Darren
    Lives in Marple Stockport, United Kingdom. Last Activity: 11 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,348. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Welcome to the forum Darren I am sure you will find all the help you need here. As usual standard advise don't buy any kits of parts or hardware until you have your design done as it WILL change over time and the parts in the kits are never matched to each other.
    Start a build log so that you can keep all the questions in one place. Good luck with the build or design.
    Hi Darren
    Welcome
    As usual good advice from Clive, have a look through the build logs first as the information in them is priceless. there was a post last week about a machine that i think was designed by jazz and looks a cracker,
    http://www.mycncuk.com/threads/9694-...me-CNC-builder
    I will be following your build with interest as it's the same size as i would build if i ever get round to it.
    Enjoy the forum.
    Regards
    Mike
  5. The Following User Says Thank You to mekanik For This Useful Post:
  6. #4
    Thanks guys, I have a few questions then once have some answers and have decided on a couple of things i will be ready to reveal my design.
  1. NEW MEMBER: Greetings From Essex
    By trounce in forum New Member Introductions
    Last Post: 18-01-2011, 02:06 PM
  2. NEW MEMBER: New member from Essex
    By swarfy in forum New Member Introductions
    Last Post: 08-12-2010, 01:38 PM
  3. NEW MEMBER: Hello from Essex UK
    By Kn8 in forum New Member Introductions
    Last Post: 04-06-2009, 07:53 PM
  4. NEW MEMBER: New member from Suffolk/Essex/Cambridge
    By richb77 in forum New Member Introductions
    Last Post: 18-10-2008, 12:04 PM
  5. NEW MEMBER: New Member - Essex UK
    By alan2525 in forum New Member Introductions
    Last Post: 16-10-2007, 01:43 PM
