Thread: How to drill gems?
03-04-2016 #11
03-04-2016 #12
If the holes were bigger I'd have suggested the old low speed tubing & abrasive paste method, maybe sections of hypodermic needle & diamond paste would work but you'd need a system of regularly lifting & then reapplying drilling pressure
03-04-2016 #13
Luckily precision is not the aim here but quantity. The holes have to be on a precise place, could be slightly tapered and sizes could slightly vary. This is not drilling rubies for watches. Just jewelry.
I spoke with my friend and he said 1.2 to 1.5mm holes are ok. So i will forget for holes below 1.2mm. So seems a china spindle with VFD will work right and have acceptable speed. May be even better will be one of the small Dc spindles. The question here is if that should be driven down by motor, lever or just counterbalanced and let its weight drill slowly the stone.
03-04-2016 #14
Its possible that weight or lever with straight down feed will both result in a hole jammed up with powder and shed diamond cutting debris with significant tool life reduction, if you combined one of those two with table moves to cut 1.5 holes with 1.2 cutters and air to clear dust you might be onto a winner
- Nick
VFD for drill press
By Noplace in forum Motor Drivers & ControllersReplies: 14Last Post: 31-03-2016, 12:09 PM -
CNC drill bit conundrum...
By HankMcSpank in forum Tool & Tooling TechnologyReplies: 10Last Post: 06-07-2015, 04:37 PM -
Pillar drill
By dudz in forum Tool & Tooling TechnologyReplies: 1Last Post: 24-08-2014, 12:08 PM -
drill size
By luke11cnc in forum Tool & Tooling TechnologyReplies: 3Last Post: 09-08-2011, 12:25 PM -
best drill bits
By oadamo in forum Tool & Tooling TechnologyReplies: 4Last Post: 01-01-2011, 11:25 PM
