    Have a friend into jewellry not sure where she buys her drills but what you are looking for are "bonded diamond drill bits" if I can get hold of her I will try and find out her european suppliers and PM you the details, but I know she also imports a lot from from the States because its cheaper.
    https://emvioeng.com
  3. The Following User Says Thank You to komatias For This Useful Post:
    Quote Originally Posted by lucan07 View Post
    Great, it would be good to know what she is using exactly. So " bonded" is "METAL BOND (SINTERED) " right?
    Quote Originally Posted by komatias View Post
    Thanks. I googled but as i said so many China crap which confuses me. And the above are 50$ per bit . So i would like to know what really works well . This one seems interesting as he says on ebay listing that this is the one that China factories use for bead drilling. They are cheap enough to try. Allright i will buy them. He sells 1.5mm and 2mm.
    That still leaves to find the micro drills 0.8-1mm
    I also saw some diamond micro twist drills?
    phill05's Avatar
    Lives in Derbyshire  UK, United Kingdom. Last Activity: 10 Hours Ago Has a total post count of 302. Received thanks 30 times, giving thanks to others 13 times.
  6. #5
    i saw that at their page : Recommended Feed Rate: down or side feed: .010" per minute.
    And 35,000 to 150,000 RPM that's some spnidle
  8. #7
    Found a receipt with some drills I got from her last year and on that occasion she had purchased from covington-engineering.com in the states I know she travels to california regularly so a place to start they seem to stock most things related.
  9. The Following User Says Thank You to lucan07 For This Useful Post:
  1. VFD for drill press
    By Noplace in forum Motor Drivers & Controllers
    Last Post: 31-03-2016, 12:09 PM
  2. CNC drill bit conundrum...
    By HankMcSpank in forum Tool & Tooling Technology
    Last Post: 06-07-2015, 04:37 PM
  3. Pillar drill
    By dudz in forum Tool & Tooling Technology
    Last Post: 24-08-2014, 12:08 PM
  4. drill size
    By luke11cnc in forum Tool & Tooling Technology
    Last Post: 09-08-2011, 12:25 PM
  5. best drill bits
    By oadamo in forum Tool & Tooling Technology
    Last Post: 01-01-2011, 11:25 PM
