ok I will join but question based off the feed back this is the machine I decided to buy ( Water Cooling 50W CO2 Laser Engraving Machine Engraver Cutter Build-in Air Pump){http://www.ebay.com/itm/like/1215452...&ul_noapp=true} what do you think
02-05-2016 #2
Advice for when it arrives water cooling is vital letting the tube get over temp will kill it very quickly, operating at 100% will reduce life of tube so use minimum required to do job, there are suppliers of MDF and PLY for laser cutting that cut much easier and better than standard supplies couple fo examples just first to come up on google below these have been manufactured for laser cutting and some older PLY etc is difficult to cut with laser. Make sure mirrors and lenses are always kept clean and aligned and protect eyes at all times.
https://hobarts.com/sheet-materials/...mdf_124_15_55/
https://www.kitronik.co.uk/materials...xkxRoCq_rw_wcB
02-05-2016 #3
And for the love of machinery, use deionised water and 5% automotive antifreeze as coolant. Not tap water.
https://emvioeng.com
The Following User Says Thank You to komatias For This Useful Post:
04-05-2016 #4
thanks guys you have all been a huge help and have saved me a lot of time money and headache i thank you all for the great advice.
04-05-2016 #5
By the way is there basic software that will allow me to do different font letters and different shapes.
05-05-2016 #6https://emvioeng.com
05-05-2016 #7
Don't use a lot of the other software mentioned but inkscape has many plugins that tend to be missed, but I use inkscape to generate G-code directly for my engraver/cutter powerful program once you get to know your way around and its free.
What 'decent' Milling machine?
By Chaz in forum Milling Machines, Builds & ConversionsReplies: 74Last Post: 21-06-2015, 04:32 PM -
Will steel angle work for a decent machine?
By amd7000 in forum Gantry/Router Machines & BuildingReplies: 13Last Post: 06-06-2015, 12:47 PM -
eBay: Looks a decent little machine
By EddyCurrent in forum Items On eBay UKReplies: 13Last Post: 12-09-2013, 04:55 PM -
A decent little (PCB miilling) Chinese machine...
By HankMcSpank in forum Machine DiscussionReplies: 5Last Post: 18-06-2013, 06:59 PM -
BUILD LOG: small mill for machining steel. Max spend £500 including computer
By Andrew Wilding in forum DIY Mill Build LogsReplies: 44Last Post: 20-07-2012, 03:46 PM
