	18-06-2016 #1
I am using Rd Works to operate my CNC 50w cutter its the only program I can get to work with my machine still trying to figure out how to fill in objects and add layers other then that it works fine. I am also trying to figure out the best speeds to use with my cutting power which I keep under 75 and also the best wood to use I look forward to the good advise I always seem to get on here.
The CEO
FOR SALE: Denford MIRAC CNC Lathe. Single Phase. Absolutely complete and perfect running order.
By Nick Butler in forum Items For SaleReplies: 19Last Post: 21-08-2013, 11:20 PM -
Make your own Super- PID ... not that hard to make ! .... says electronics genius!
By Buba b in forum General ElectronicsReplies: 4Last Post: 26-04-2013, 08:37 AM -
Need a perfect 8mm hole - to ream or bore?
By HankMcSpank in forum Machine DiscussionReplies: 26Last Post: 12-03-2013, 12:42 PM -
a perfect 90deg joint - 15mm Alu
By dsc in forum Gantry/Router Machines & BuildingReplies: 12Last Post: 24-02-2013, 01:31 PM -
Not cutting perfect right angles and sticking on Y axis ?
By Fivetide in forum Milling Machines, Builds & ConversionsReplies: 7Last Post: 10-12-2012, 09:41 PM
