02-04-2016 #11
I am in the US
02-04-2016 #12
02-04-2016 #13
Just to throw a curve-ball here.
Komatias - how do you find cutting wood affects the optics? (I'm thinking resinous smoke deposits on the mirrors) - Not necessarily a game-changer, but I'm thinking that it needs to be considered here. I would agree if you can cut with a laser this must be a good, viable solution, but I have avoided particle/laminate boards up to now with my 40W chinese (not that acrylic is particularly clean).
I'm surprised that 50W will cut 1/4" - but will take your advice on this. Perhaps I need to grow a pair and get some ply in mine - I've plenty of 1/4" knocking about and a project that needs an enclosure (ironically, to contain a laser - but only 1W 450nm... though that nearly set fire to my shed). Maybe a couple of passes will get through.Last edited by Doddy; 02-04-2016 at 10:35 PM.
02-04-2016 #14
Ok Komtias I looked at one of these machines looked small is that big enough to make a 11inch tall and 10inch wide letter plus what type of power does it use.
02-04-2016 #15
The total sign was 1.4m long. I split the letters and nested them on multiple 600x250mm sheets. The designer I did this for, then tacked and glued all the letters together.
Wood makes a lot of smoke but that is why you will need to buy a good extractor fan.
Most lasers nowdays come with air assist. This is basically a nozzle that allows air to come out where the focused laser beam exits. It also ensures that you dont start a fire while cutting. You really only clean the final concentrating lens once a month.https://emvioeng.com
02-04-2016 #16https://emvioeng.com
02-04-2016 #17
Although not 80W this one is one that I would definitely consider buying it has 700x500 cutting area (27"x19"). Again at the price you will need to ensure you are up to the task of maintaining it.
http://www.ebay.com/itm/1-Value-USB-...AAAOSwHnFV2tp4
I see that the 80W are roughly twice as expensive and considering you can get most of the work done with 60W, I do not think you need any more than that.https://emvioeng.com
03-04-2016 #18
Yup, mine came with an air-assist nozzle - and a handful of coiled rigid air pipe. That quickly got replaced with an energy-chain to contain a flexible (ok, aquarium) 4mm silicone air tube, as well as a 2-core ribbon to supply the two laser line-generators that a 3d-printer bracket held to provide x-hairs (don't think to use a x-hair lens/laser assy, as you can't guarantee the focus/alignment, you really do need two single line generators, one on each axis).
My real problem with chinese lasers is the absolutely crap software. I need to adapt the machine to be driven from g-code, but I've struggled to justify the cost.
03-04-2016 #19
i hear you on the laser but it just seems like to me that a drill bit would cut wood cleaner and better than a laser maybe not metal but definitely wood,
03-04-2016 #20
absolutely not, a laser will cut it faster and a lot cleaner than a router.
What 'decent' Milling machine?
By Chaz in forum Milling Machines, Builds & ConversionsReplies: 74Last Post: 21-06-2015, 04:32 PM -
Will steel angle work for a decent machine?
By amd7000 in forum Gantry/Router Machines & BuildingReplies: 13Last Post: 06-06-2015, 12:47 PM -
eBay: Looks a decent little machine
By EddyCurrent in forum Items On eBay UKReplies: 13Last Post: 12-09-2013, 04:55 PM -
A decent little (PCB miilling) Chinese machine...
By HankMcSpank in forum Machine DiscussionReplies: 5Last Post: 18-06-2013, 06:59 PM -
BUILD LOG: small mill for machining steel. Max spend £500 including computer
By Andrew Wilding in forum DIY Mill Build LogsReplies: 44Last Post: 20-07-2012, 03:46 PM
