Ok Komtias I looked at one of these machines looked small is that big enough to make a 11inch tall and 10inch wide letter plus what type of power does it use.
02-04-2016 #2
Although not 80W this one is one that I would definitely consider buying it has 700x500 cutting area (27"x19"). Again at the price you will need to ensure you are up to the task of maintaining it.
http://www.ebay.com/itm/1-Value-USB-...AAAOSwHnFV2tp4
I see that the 80W are roughly twice as expensive and considering you can get most of the work done with 60W, I do not think you need any more than that.https://emvioeng.com
What 'decent' Milling machine?
By Chaz in forum Milling Machines, Builds & ConversionsReplies: 74Last Post: 21-06-2015, 04:32 PM -
Will steel angle work for a decent machine?
By amd7000 in forum Gantry/Router Machines & BuildingReplies: 13Last Post: 06-06-2015, 12:47 PM -
eBay: Looks a decent little machine
By EddyCurrent in forum Items On eBay UKReplies: 13Last Post: 12-09-2013, 04:55 PM -
A decent little (PCB miilling) Chinese machine...
By HankMcSpank in forum Machine DiscussionReplies: 5Last Post: 18-06-2013, 06:59 PM -
BUILD LOG: small mill for machining steel. Max spend £500 including computer
By Andrew Wilding in forum DIY Mill Build LogsReplies: 44Last Post: 20-07-2012, 03:46 PM
