02-05-2016 #27
Advice for when it arrives water cooling is vital letting the tube get over temp will kill it very quickly, operating at 100% will reduce life of tube so use minimum required to do job, there are suppliers of MDF and PLY for laser cutting that cut much easier and better than standard supplies couple fo examples just first to come up on google below these have been manufactured for laser cutting and some older PLY etc is difficult to cut with laser. Make sure mirrors and lenses are always kept clean and aligned and protect eyes at all times.
https://hobarts.com/sheet-materials/...mdf_124_15_55/
https://www.kitronik.co.uk/materials...xkxRoCq_rw_wcB
What 'decent' Milling machine?
By Chaz in forum Milling Machines, Builds & ConversionsReplies: 74Last Post: 21-06-2015, 04:32 PM -
Will steel angle work for a decent machine?
By amd7000 in forum Gantry/Router Machines & BuildingReplies: 13Last Post: 06-06-2015, 12:47 PM -
eBay: Looks a decent little machine
By EddyCurrent in forum Items On eBay UKReplies: 13Last Post: 12-09-2013, 04:55 PM -
A decent little (PCB miilling) Chinese machine...
By HankMcSpank in forum Machine DiscussionReplies: 5Last Post: 18-06-2013, 06:59 PM -
BUILD LOG: small mill for machining steel. Max spend £500 including computer
By Andrew Wilding in forum DIY Mill Build LogsReplies: 44Last Post: 20-07-2012, 03:46 PM
