    Looking for quote for a chrome plated piece of steel (see attached document).
    Summary:
    4mm thick steel, chrome plated
    50mm x 250mm
    2 x 30mm diameter holes, 180mm apart (centre to centre)
    Look forward to your quotation.
    Attached Files Attached Files
    Cliff,
    You could actually do this yourself unless there is a reason why you don't want to. Search local water jet cutters or laser cutters. Water giving the better finish. If there is any reason either of those finishes wont be be good enough it could be machined. Then find a local Electro platers yell.com if a good source of info. Find one that chromes and you're good to go, they should take care of the polishing prior to plating if its required. The only thing to be wary of is make sure the sheet that is used is cold rolled and good condition (not heavily scratched or marked) and not hot rolled, hot rolled will be covered in scale and be a lot of work before plating and the finished part could well be a bit of a mess.
    I can certainly look at pricing it for you but you would be paying someone for something you could get done yourself.
    I hope this is helpful.
    Last edited by spluppit; 03-04-2016 at 12:47 AM. Reason: I'm stupid and can't type
  1. My latest Piece
    By Jester in forum Woodworking Project Showcase
    Last Post: 20-06-2014, 09:08 AM
  2. Aluminium Warehouse contact details
    By m_c in forum Marketplace Discussion
    Last Post: 09-08-2013, 09:31 AM
  3. RFQ: PC Table, MDF 25mm - All files enclosed
    By craigrobbo in forum Projects, Jobs & Requests
    Last Post: 04-05-2013, 08:47 PM
  4. Ballscrew machining details
    By HiltonSteve in forum Lead Screws, Nuts & Supports
    Last Post: 24-07-2009, 04:01 PM
