    kell's Avatar
    Lives in doncaster, United Kingdom. Last Activity: 15-12-2024 Has been a member for 9-10 years. Has a total post count of 53.
    I must be doing something wrong, and I am sure it is obvious but I am missing it as usual.
    After loading g code and setting tool , my tool tip in on material at zero, when I push cycle start it move directly to first position instead of lifting and clearing material first.? Just wait now for the first person to tell me the obvious.
    Let us know what controller/software/machine you are using. Sounds like you don't have a safe Z clearance distance setup.
    kell's Avatar
    It is Mach 3 and it dose say safe z not set but not sure how to set it
    Unfortunately I don't use Mach3 as yet so you'll need to hang around until someone else wakes up.
    I normally set up my safe Z clearance height in the cad/cam software before it gets to my controller.
    What are you using to create the G code?
    kell's Avatar
    I'm using solidcam
    I don't use solidcam either so I'm not being much help to you. Somewhere in the material or milling operation setup in solidcam there will be a box for you to input a safe z distance. It might be labelled as clearance distance or something like that. You would normally set that distance so that the cutting tool would be able to clear the workpiece and any jigs or fixtures above the material.
    Quote Originally Posted by kell View Post
    After setting zero move Z up to your clearance plane before starting the job.
    The software which generates your code will assume your machine is starting from a homed position - well above the work.
    When we manually set a zero we often need to leave the machine as the CAM software would expect to find it - with the tool well clear of the work,
    Regards,
    Nick
    It's SolidCAM's responsibility to lift the tool, not Mach3.
    Mach3 just does what SolidCAM is telling it.
    Gerry
    UCCNC 2022 Screenset
    Mach3 2010 Screenset
    Tut tut Mark you wasn't paying attention was you when I showed you last time. . .Lol
    If get done early enough tomorrow (fri) I'll call on way from work and show you.
    Lives in Marple Stockport, United Kingdom. Last Activity: 17 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,346. Received thanks 619 times, giving thanks to others 89 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
  1. Electronic sound on steppers on slow move
    By eurikain in forum Stepper & Servo Motors
    Last Post: 29-03-2016, 01:02 PM
  2. Replies: 8
    Last Post: 02-11-2015, 10:32 PM
  3. First go at Fusion 360 Adaptive Clearing
    By Washout in forum Fusion 360
    Last Post: 15-10-2015, 07:52 PM
  4. Massive mig welder hell to move
    By GeorgeD in forum Welding, Brazing & Equipment
    Last Post: 09-08-2010, 10:45 PM
