No is the Short answer. The long answer is too long and I'm too tired to write what I know but what I will point out is that M4 doesn't come with any Pulse generation.??
By that I mean if you want to Run parallel port you have to Buy the PP plug-in. If not then the Motion controller your using must provide the Plug-in for there Pulse engine and here in lies the Problem in that Some are more advanced than others.
So what are you using for Motion.?Last edited by JAZZCNC; 02-04-2016 at 08:28 PM.
02-04-2016 #2
Using CSMIO-M , which is why I'm considering upgrading. I guess I'll give it a try, thanks all
02-04-2016 #3
03-04-2016 #4
Would one be in an equally (or close to) good spot if PoKeys57CNC was the board in use?
03-04-2016 #5
04-04-2016 #6
Vital Systems is supposed to be right up there at the top with Mach4 support, but they can be pricey when you start adding options.
Gerry
UCCNC 2022 Screenset
Mach3 2010 Screenset
Gerber System 48 with Mach 3 software training required!
By Ahmed in forum Opportunities Available & SoughtReplies: 0Last Post: 07-11-2013, 08:56 PM -
Mach3 vs Mach4
By Saracen in forum Artsoft Mach (3 & 4)Replies: 42Last Post: 15-09-2013, 04:55 PM -
WANTED: xp pro computer, with mach3 license and maybe vectric on it with license
By nobby in forum Items WantedReplies: 2Last Post: 28-06-2013, 09:10 PM -
advice on software and machine required please.
By iamspuddy in forum CAD & CAM SoftwareReplies: 9Last Post: 18-04-2012, 08:14 PM -
mach3 license help
By Keith Rumsey in forum Artsoft Mach (3 & 4)Replies: 2Last Post: 08-02-2009, 01:32 PM
