Thread: 250mW LASER stuck on
12-07-2009 #8
I reckon you need to establish what the cutoff voltage for your FET really is (as it's being help 'on' all the time)....like I say the 'actual' can differ somewhat from the 'spec'.
here's what I'd do...
('scuse the scribble ....back of an envelope - literally, & while cookinng the family bacon sarnies with my other hand!!)
...you'll need a variable resistor** (can be any value really)...just adjust the pot's wiper until the LED turns off & then measure your voltage at the gate. I reckon you'll find your fet needs more than +5V to turn it off. If so, you'll need a FET with a low cutoff voltage.
** if you don't have a variable resistor you could use a resistor chain to get different voltage presented at the gate. Eg a 5k + 5K resistor chain will give you 6V at the gate etc.Last edited by HankMcSpank; 12-07-2009 at 01:13 PM.
feedrate stuck on low
By routercnc in forum Machine DiscussionReplies: 1Last Post: 24-04-2014, 10:24 PM -
Laser cutter
By John S in forum Laser Machines & BuildingReplies: 8Last Post: 02-06-2012, 02:16 PM -
WANTED: GCc Laser Pro or Epilog Laser Cutter Machine
By Brownhills school in forum Items WantedReplies: 1Last Post: 10-05-2012, 04:30 PM -
help with cnc laser
By swinds in forum Laser Machines & BuildingReplies: 11Last Post: 09-01-2012, 10:15 PM -
new laser
By mike techserv in forum Milling Machines, Builds & ConversionsReplies: 6Last Post: 06-06-2009, 02:17 PM
